S-Tronic Sport Mode Weird?
Rexus Apr 14, 2014
  1. Rexus
    Rexus Active Member
    106
    29
    I have a 1.4 COD S-Tronic and have been mainly using the Gearbox in auto "D" mode the past few weeks as I ran the car in. In the past couple of days, I've used the "S" mode at times and as expected it changes up at higher revs and significantly changes the car's performance. However, what I find strange is when I've accelerated to around 70mph and then continue to drive at that speed the gearbox stays in 5th rather than changing to 7th gear as I would have expected, obviously affecting economy. Anyone else have this experience?
  2. The Challinor
    The Challinor Well-Known Member Audi S3
    4,582
    1,258
    Surely that's just "S" mode as it's ready to go at any moment, drop down for overtake, power way past 70 at as fastest time as possible, etc
    SlightlyYapper likes this.
  3. RobH_S3
    RobH_S3 Active Member
    440
    208
    43
    S mode is supposed to put you at optimum revs at all times. It doesn't know your cruising at 70 or hammering it around a track. Personally never use it much prefer manual mode.
    SlightlyYapper and TonyH38 like this.
  4. Rexus
    Rexus Active Member
    106
    29
    Yeah, I agree with all that, it's what I would have expected in Sport mode, what I would like to do is leave it in that mode but have top gear selected at high speeds when not accelerating to maximise economy, then have the gears drop down as soon as I open the throttle again. At the moment to achieve that I have to use S mode if I want to accelerate quickly then switch to D mode for economy when cruising then switch back to S mode if I want to accelerate quickly again, a bit of a pain really.
  5. RobH_S3
    440
    208
    43
    Have you tried putting it in dynamic mode but changing it from d to s. That holds gear a bit longer than say comfort.
  6. Rexus
    Rexus Active Member
    106
    29
    No, I'll have to try that, have it in Auto at the moment.
  7. RobH_S3
    440
    208
    43
    Its a bit more keen to change down as well when you need too. I always have it in that setting when just cruising.
  8. ColMariner
    ColMariner Active Member
    136
    75
    In my experience still accelerates quickly wether in S or D, as if you press accelerator right down will drop you to lowest possible gear and if you keep foot hard down will only change before limiter. Hardly a pain either just a quick flick of the gear stick, did you drive everywhere in 1st when you had a manual :whistle2:
  9. Rexus
    Rexus Active Member
    106
    29
    When I had a manual, I expected to use the gearshift and clutch; when I drive an automatic I expect not to have to, that's why I chose it this time.
    The point you make about the kick down is a good one, I'd forgotten about that will have to try it.
  10. ColMariner
    136
    75
    Excuse my sense of humour, they really are a great gearbox, dont think will go back to manual, just takes some time getting used to them. I hardly ever put mine in sport and only generally use paddles at roundabouts as find coming out of them in 5th gear a bit annoying if its left to its own devices.
  11. Cumbrian_bob
    Cumbrian_bob Member
    227
    104
    Makes perfect sense, and sounds much like the A1 Stronic box, which i think is the same 7 speed dry clutch unit. I am pretty sure the A1 even states its a 6 gear in S mode and 7 gear in D mode. when driving with full accelarion sport mode it can do its top speed 140 with 6 gears so why bother using all 7 if its in sport mode. The 7th gear desienged for fuel economy wouldnt be much good in a sport mode.
    The rev ranges are higher in S mode, changing at the red line and not dropping to low. It would be interesting to know if in S mode if it ever lets the the engine run with less cylinders, in theory they should always be on ready for immidiate use as Sport mode would suggest by its name
  12. andywil13
    andywil13 Active Member It's my birthday
    380
    68
    I agree with this. I find that when slowing down for a give way it's still in Maybe 4th, whereas I would have preselected 2nd in a manual. I simply switch to sport mode at this point and then back to D after completing the maneuver. Same for roundabouts etc
  13. Pulp84
    Pulp84 Well-Known Member Audi S3
    2,235
    1,135
    Yes I do this sometimes as find that you may pull out of a junction and the box is in 4th and out of no where you will get some numpty coming at you way too fast and you have to put your foot down. Only issue with this is sometimes my S-Tronic gets a bit confused and it takes a couple of seconds to sort its life out kicking down etc (down to 2nd which would have been more appropriate).
    Annoying but S mode works fine in these situations so it's fine.
  14. Joetidman
    Joetidman Well-Known Member
    1,103
    582
    Although I've just found out that in an S3 4th is just fine in that situation....:)
