S-Tronic gearboxes
Agent_Trig Feb 15, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    I've been told that the DSG gearboxes are twin clutch paddle types which come under the name of S-Tronic.
    Is this true?
    Would you rate this kind of box better than a proper manual?
    My current car (FTO) has a Tiptronic gearbox and my main gripe with this is that it zaps about 20bhp from the wheels.
    Is the same to be said of the S-Tronic box?
  2. Matt2010
    Matt2010 Member
    40
    Never driven an A3/S3 with a manual but there fine and actually a little quicker to 60 with S-Tronic.
    Manuals will be a thing of the past before long (can of worms opend) ;)
  3. Agent_Trig
    Agent_Trig Member
    552
    Are all S-Tronic A3's fitted with DSG paddles?
  4. sub39h
    sub39h Active Member
    2,502
    yes.
    it's a phenomenal gearbox. i'll never own a manual again. ever.
  5. ron burgandy
    ron burgandy Active Member
    303
    49
    so are s tronic the same as the dsg gear boxes
  6. Harrelson
    Harrelson Member
    173
    A torque converter is what robs the engine power in automatic trans.
    S-tronic (commonly known as dual clutch or double clutch) does not use a torque converter, rather two clutches, one for even and one for odd gears. It uses vey little engine power -to run the oil pumps (in wet clutches)
    -and the hydraulics that change cogs
    Is it better than manual? In my opinion YES
    -more economical (6th gear can be very tall for cruising)
    -can be driven in either manual (change gears yourself) or fully automatic mode
    -does not need replacing every 60,000miles
    -very smooth shifts in automatic mode
    -power to the wheels is not interrupted when changing gear, hence faster than manual
    -some systems blip the throttle for you, so you get lower gears without heel n toe'ing
    Disadvantages
    -more expensive to specify but adds resale value later
    -expensive repairs if there is a malfunction
    -servicing is expensive
    -slight delay when changing gear in some situations
    If you're thinking of specifying one, take one out for a testdrive. I haven't driven an Audi with DSG, but driven a Porche with PDK and its mindblowingly good. Better than a manual for a daily car
  7. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,398
    509
    There may be slight revisions to the gearbox internals, but afaik it was just a rename, so Yes they are the same. Don't confuse one with a standard automatic gearbox that needs a lifetime to change gear, these are far superior to that, purist will argue you can't beat a manual box, but IMO the dsg is fantastic!
  8. sub39h
    2,502
    DSG = S-tronic = DSG = S-tronic = DSG = S-tronic
    just to clear up any confusion
  9. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,365
    203
    I agree with all thats said except the expensive to service bit. They require an oil change at 40k miles but thats about it.
  10. paddy
    5,365
    203
    Naa ! I'm confused :) so whats a multitronic and a autoclutch ? :)
  11. Minstadave
    Minstadave Member
    560
    19
    It's £170 each time though so not insignificant, having said that its pretty infrequent.
  12. paddy
    5,365
    203
    Quite agree, not trying to be difficult. Most people will only need to do it once in their ownership. I was told they were expensive to service when i bought mine 4 years ago and had visions of them needing adjustments or a partial strip when i heard the word "service".....lol so i was just pointing out its just an oil change/filter.. all be it about 6-7 ltr's :)
  13. Agent_Trig
    Agent_Trig Member
    552
    When I look at the interior photos of S-Tronic A3s, I can never see the paddles behind the steering wheel.
    Are they tiny or something?
  14. akbarirfan
    akbarirfan Member
    99
    From what I can see, the 2.0 TDI 170 bhp DSG is more commonly referred to as S-tronic rather than DSG, and the 140bhp is called the DSG.
    I asked this question when I first signed up on here, they are both the same.
  15. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    Its a truly fantastic gearbox, i'd never have manual again! I paid less than £100 from an Indi garage for my oil change and I cant even feel it when it changes!
  16. N8
    17,163
    719
    I will depends on the car, but DSG rocks, one of my fav things about my car :wub:
  17. sub39h
    2,502
    hmm i'd be tempted to agree, but i think any car worth it's salt nowadays will have a decent automated gearbox of some description
  18. N8
    17,163
    719
    If it was an R8, manual ADL for me...
  19. sub39h
    2,502
    but that's because R-tronic is **** (supposedly - i've never driven an R8). anyhow i reckon the next gen R8 will have a variant of S-tronic. if the RS5 has it and basically has the same engine then it can cope with the power - not sure if it's compatible with the rear engine quattro layout tho
  20. N8
    17,163
    719
    But regardless, manual in an R8 ADL.
  21. LWNY
    LWNY Member
    161
    bcuz these flappy paddles turn with the steering wheel, you don't need humongous ones like on the ferrari 458, which goes almost all the way around. it will not suit the guidos west of atlantic that drives with one hand at the 12 olcock position, nor the guidos east of atlantic that drives with fingers at 6 oclock position, nor for shuffle steerers, who almost always have their hand in the 9-11 and 1-3 oclock position, no matter where the actual position of the steering wheel is. But for drivers who always has steer with their hand on the 9 and 3 oclock position of the steering wheel when it is pointing straight and never release it unless the steering wheel has to turn so much, the size of the flappy paddles is fine.
  22. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    Only time I have an issue with the placement of the padles is when making a sharp turn at a T-Junction, the gearbox will upshift when you hit the redline anyway, but that can be a bit noisey in a TDi.
    Paul
  23. Ads
    Ads License to drive
    8,230
    612
    So have you worked out whether it's a haldex oil change or DSG one yet?? :lmfao: :ninja:
  24. N8
    17,163
    719
    Sounds nice with a TBE straight through on the TDI :wub:
  25. paddy
    5,365
    203
    Get back down the GYM :p:kiss:
  26. Ads
    8,230
    612
    Thought I was on your ignore list? :laugh:
  27. paddy
    5,365
    203
    I took you off ther ignor list and put you in the corner with a pointy hat on. :lmfao:
