S Mode - DSG Box
DaveA3-TDI Feb 8, 2012
  1. DaveA3-TDI
    DaveA3-TDI Member
    249
    Had my S-Line TDi for a while now and have never really used the S mode on the DSG box, normally just use it day to day in D mode.
    This might be a silly question but whilst driving in D mode is it ok to go between the D mode and the S mode or should you stop and select the different modes? Just wondered if the box can cope with it or could it be damaging over a period of time?
    How does everybody use their S mode?
  2. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    You can switch with no problems and no damage. S mode everytime when you need 100% of the car's performance (overtakes, racing some chavy idiots etc)
  3. mjr901
    mjr901 Guest
    As above. play with S mode whilst going. it's fine. it drops it down a gear and has your ready for the "off" :)
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,382
    214
    No problem Dave, its designed to go between S and D on the move. Drop down to S when you are waiting for that gap to overtake .
  5. RedDejavu
    1,806
    337
    I even tested out going from S to N lol by mistake and nothing happend aprat from stopping instantly.
  6. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    I use the 'D' in just everyday casual driving but when you want a bit of extra umph, slap it down and let the good times roll ;)
  7. Indy
    Indy Member
    119
    My mum used to have a Q7 and as soon as I introduced her to the 'S' mode she NEVER used 'D' again, even for normal driving. Probably explains why her fuel bills started to rise lol!
  8. jb0o
    2,664
    118
    You certainly see a difference in S. When I first got my 2.0TFSI my first thought was "this is a bit slow.." but that was because in D you'll change gear at 1800rpm which means upon exiting a round-a-bout you'll be in 4th gear... not the ideal gear for a quick get away.
  9. Adam.
    Adam. Meow.
    662
    34
    S in a diesel is stupid as it always revs to the redline.
    It was good in my Leon as that was mapped so naturally pulled till the line but in the A3 it is ****.
    Oh and I stalled it once going from S to D lol.
  10. Tracebuzta
    Tracebuzta Member
    97
    I dont use S a lot on my 3.2, but when I do...... :racer: :rockwoot:
  11. DaveA3-TDI
    DaveA3-TDI Member
    249
    thanks, will try it out on the way home tonight then lol
  12. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,286
    627
    D or Manual for me.
  13. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    570
    154
    43
    I find S mode just holds onto the revs for longer in my Mum's 170TDi Touran with the DSG. Pretty pointless when diesels produce their power / torque low down. In petrol variants I can see it would benefit though.
  14. IceHanger
    IceHanger Active Member VCDS Map User
    340
    64
    The S mode from what I can gather in mine doesn't just hold onto the revs longer, I can hit ~7k with mine D, it just doesn't change up when the load come off like in D (lifting the foot slightly etc)
    So S mod is perfect for fast driving and roundabouts, as in D you always get the drive in to the roundabout put foot down to exit.....annnnnddd it changes down down.
    Yup it's way quicker for overtakes as it puts you in the right gear.......
    but you know you can just grab the left paddle when it's in D and it changes to manual mode?
    and it stays in that until back into 6th and cruising unless you flick the stick to the left and back again.
  15. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    Diesels have torque at lower RPM but the power is still at higher RPM.
  16. mjr901
    mjr901 Guest
    Or you can hold the right paddle down and it goes back to D mode. ;)
  17. RedDejavu
    1,806
    337
    on the S mode downshifts are quite brutal though.
