S-line grill removal help!!
Davis_2012 Feb 11, 2013
  1. Davis_2012
    Davis_2012 Member
    56
    Right so I've purchased an S3 grill for my s-line, I know how to remove the bumper. But I'm none the wiser on how to remove the grill?? Anybody out there able to advise me on how to do this, or point me in the direction of someone who might have a step by step guide??
  2. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    How old is your A3?
  3. Davis_2012
    Davis_2012 Member
    56
    2007 pal
  4. aaronthew
    aaronthew New Member
    15
    after you have the bumper off take out the 2 Philips screws on the back of the grill, then with a bit of force and alot of patients push each tab through
  5. aaronthew
    15
  6. Davis_2012
    Davis_2012 Member
    56
    Thanks mate that's where I got stuck pushing the clips out, what's the best way to push them through??
  7. rOb_A
    rOb_A Active Member
    1,488
  8. aaronthew
    15
    flat screw driver or pliers takes a while done my Thursday night
  9. Watty
    Watty ..... (_!_) Sarah's A3s #1 Fan
    404
    I thought the S3 grill was shorter in height than the S-Line?
  10. A3Kent
    1,571
    249
    Not if it's the same age car. The Pre mid 2008 cars are a different size to the mid 2008 onwards cars.
  11. Davis_2012
    Davis_2012 Member
    56
    Gonna give it a go with pliers tomorrow
  12. rOb_A
    rOb_A Active Member
    1,488
    good luck with that
    Davis_2012 likes this.
  13. Davis_2012
    Davis_2012 Member
    56
    And the outcome is the grill doesn't fit hàha
  14. A3Kent
    1,571
    249
    Sounds like you've purchased a facelift (8P3) grille rather than the one that will fit your 07 reg car.
    Got a photo of it? Or one that looks like it on google?
  15. Davis_2012
    Davis_2012 Member
    56
    I was told its 2008 but pre-facelift??
  16. A3Kent
    1,571
    249
    It is, it should fit. Where doesn't it fit?
  17. Davis_2012
    Davis_2012 Member
    56
    It's about an inch short on the height and none of the clips down the side and bottom line up
  18. A3Kent
    1,571
    249
    Just found this mate - VWVortex.com - pre-facelift premium and S-line grills are different, F#$K!!
    Sounds like the S3 grille on the pre-facelift is shorter than the standard and S-Line grilles where as the facelift grilles will fit on any facelift A3/S3. You learn something new every day.
    Doesn't help you I know but at least you aren't the only one who's tried.
    BTW...Watty, you were spot on, sorry buddy.
  19. Davis_2012
    Davis_2012 Member
    56
    Ah man that sucks so its pretty useless unless I was to get a S3 front bumper?
  20. A3Kent
    1,571
    249
  21. Davis_2012
    Davis_2012 Member
    56
    Yeah I've listed the grill on eBay see what I can get, might look into the FK grill
  22. Davis_2012
    Davis_2012 Member
    56
    Any idea which would be the closest to an S3 grill to fit mine?
  23. A3Kent
    1,571
    249
    It's personal preference really mate. There are lots of guys on here who have purchased these grilles and have posted photos up with them fitted to their A3's. I'll see if I can find some links and post back.
  24. A3Kent
    1,571
    249
  25. Davis_2012
    Davis_2012 Member
    56
    Cheers pal
