S Line DSG To S3 Gear Knob Conversion !
ScottPalmer Feb 26, 2012
  1. ScottPalmer
    ScottPalmer New Member
    19
    Hi Guys,
    I have ordered the new DSG S3 gear knob for my Audi S Line DSG to complete my S3 convesion ! I know how to do it as it consists of heat and twist approach but this could be very costly and honestly i dont trust myself to do it.
    So i wanted to know if anyone knew a proffesional who could do the job for me properly i have the new gear knob it would just be a case of installing would be greatlful if someone could point me in the right direction
  2. NHN
    29,331
    1,716
    Well I'm not too far from you & as its my mod originally, guess I would be someone to do for you lol.
    N8 and ScottPalmer like this.
  3. ScottPalmer
    19
    Brilliant sounds good to me mate would you be able to install the s3 dial aswell ? where abouts you live and for how much for ? Its just i dont really wanna much it up as cant be without my car !
  4. NHN
    29,331
    1,716
    S3 dials, as in S3 cluster?
  5. ScottPalmer
    19
    Yeah the rev counter dial as it has a small S3 logo on it ?
  6. NHN
    29,331
    1,716
    So lets just clarify, you have a complete S3 cluster you need fitting or just the rev counter fascia part?
  7. ScottPalmer
    19
  8. ScottPalmer
    19
    Fancy doing it for me then mate ? Do you have an estimate to the cost of the change of the gear knob ? Cheers
  9. tcardio
    tcardio Well-Known Member
    982
    283
    I assume you purchased the rev counter from Lockwood. That's an easy fix. Follow the DIY on ASN. Remember to not turn the key with the cluster detached.
    Word to the wise, twisting the pin is not the best way to do it IMHO.
    Cut the pin with a model saw
    Use a smooth nail file (finish) type and file a few times to each cut part
    Use a pin point and place a divet in the exact center of each cut end
    Drill with a 1 mm pin vise 3mm on the shift side and 2 mm on the tip side
    place a grub screw into the tip side and then attach the tip to the shifter side
    Done
    it takes 20 min and no eff up possible unless you have Parkinsons. No need for glue. Mine and others here have had ours hold up for over one year without any problems
    Any other specific questions may be addressed to tp.s3wannabe at vwvortex. he does all cars here in san francisco
  10. ScottPalmer
    19
    Thats brilliant instructions cheers mate but still i dont wanna have my car of the road would prefer it if someone like you with your expertise would do it for me i would obviously pay you for doing it sound good to you ?
  11. NHN
    29,331
    1,716
    I dont agree with that method tbh, you're basically cutting it in half which creates a weak point in the link as such, where as my original process retains the base structure & strength of the rod, each to there own of course, but for me the heat & twist with maybe some resin to make it a straight piece again is how I'd do it.
    Can swap the fascia over, assume you have a tfsi with matching rev counter numbering.
  12. ScottPalmer
    19
    I agree with you NHN you sound like you know what you are talking about ! Yeah the rev counter numbering is exactly the same ! Would you want to complete both of these cganges for me then ?
    - A3 S-Line DSG Gear Knob To S3
    - A3 Rev Counter Fascia To S3 Fascia
    I have all the parts would just be a case of you completing the labour work ?
    Wanna do it for me
  13. NHN
    29,331
    1,716
    I should do mate, its my mod copied around the world lmfao.
    PM me & we can get something sorted yes.
  14. paultaylor
    paultaylor Member
    294
    I was nervous doing the heat and twist method but I followed Nigel's instructions and it went really well
    only took about an hour and works perfectly now
  15. tcardio
    982
    283
    ^^^ that is for sure! That thread is infamous!! I can't remember but didn't someone snap off the tip after doing the mod with twist and heat only to use a screw to fix it?
  16. NHN
    29,331
    1,716
    LMFAO, I was pulling the climate out & fell backwards & snapped it of with my elbow, as the clips were stuck, but I repaired it with some resin, a pin etc as it was neccessary, buttttt did the heat twist to others & still recommend this if you have a non snapped rod :p
  17. MTRL
    MTRL Split Grill!
    459
    52
    :lmfao:
  18. tcardio
    982
    283
    hehehehehe just a little nudge to the master. agreed!!
  19. Agent_Trig
    Agent_Trig Member
    552
    Whereabouts are you based Nigel? As this is a mod I would also like to pay someone else to do :)
  20. loudchris53
    loudchris53 Member
    402
    likewise :)
    Chris
  21. NHN
    29,331
    1,716
    Based all over guys, so case of driving to you.
  22. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    Pics with the new knob?
  23. paultaylor
    paultaylor Member
    294
    here's mine
    By tallpaultaylor at 2012-02-16
    before........
  24. ScottPalmer
    19
    Mod was complete today by NHN ! Came round and did a fantastic job looks brilliant and for people who say its a 20 minute job you have no chance if you want the job done properly ! Cheers NHN i am sure i will be doing other mods with you again soon ! Pics to follow
  25. NHN
    29,331
    1,716
    Scott was a pleasure meeting you today mate, always love this mod, transforms the use of said function completely & so much better to use as such than the side button version.
    Yeah realised today even more the slice & dice is definitely not the way to do it, cause if you misalign the rod by even a mm you may have difficulty in moving it round slightly, where as the heat & twist method allows adjustments without any such issues, also importantly allows you to test with the new stick before making permanent.
    I also now use a very good & iirc costly resin, instead of the epoxy, to strengthen the heated twist, I leave for a fair while to harden then dremel it the diameter to allow up/down movement freely, that way its as strong as can be :)
    I cant stress enough you really should do all your measurements before & after, like the height of rod in park position, the height of the bottom of the hole, also if the twist isnt exactly 90 degrees the gearknob can stick & thus wont allow key removal.
  26. GG
    GG New Member
    26
    Quite fancy carrying out this mod to mine..... would need assistance though
  27. N8
    17,163
    718
    Where are you based? I'd recommend NHN do it. Mine wasn't done by him & snapped the first time, new gear selector was £400, expensive mistake :laugh:
  28. GG
    GG New Member
    26
    Im based in North Yorks..... Any idea on cost?
  29. discostu49
    discostu49 Active Member
    598
    132
    43
    How much are the knobs from the dealers, I can't see any on eBay
  30. NHN
    29,331
    1,716
    To fit, about £100, S3 ones are £91 from audi, I think I have an S3 one for sale.
