s-line bumpers
ickleric Nov 22, 2008
  1. ickleric
    ickleric Member
    91
  2. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    yes just bolts straight on but you will need the new foglight grills and centre grill.
    fog grills are about £15 - £18 each but the centre one is expensive, i think its about £90.
    well worth having though, i did this on my old a4 and it is a very smart transformation.
  3. ickleric
    ickleric Member
    91
    if i found a complete rear s-line bumper as well, does that also bolt on? also does the rear require grills?
  4. 1wheelonly
    2,386
    112
    yes its a straight forward bolt on, easy fit. no grills required on the rear.
    do you know you dont need the whole bumper,the lower sections on front and rear both fit your origial bumpers.
    if your getting them the right money then its worth buying the lot, then sell yours complete.
    is the rear one the right one for your exhausts.
  5. ickleric
    ickleric Member
    91
    do the lower bits bolt on as well? i thought you had to use adhesive and stuff.
  6. 1wheelonly
    2,386
    112
    no adhesive needed, a little trimming on the front but nothing you trim is seen after you clip te new parts on.
    how much you paying for the ones youve seen.
  7. ickleric
    ickleric Member
    91
    just looking at the moment. trying to work out the best options. i was thinking of just getting mine lower bits sprayed, but i love the s-line bumpers. i have a tight budget, so was going to slowly buy the bits i needed.
  8. 1wheelonly
    2,386
    112
    i think the front lower alone is about £90-£100 so the one you linked above isnt bad for the lot,if your cars grey.
    dont bother painting the existing one on the car now as you will always wish youd bought the s-line ones, keep saving up mate,its worth the wait,dont settle for second best,youll never be 100% with it.
  9. ickleric
    ickleric Member
    91
  10. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Nice kit, Isnt that the ATP kit (obviously a Copy)..??
  11. ickleric
    ickleric Member
    91
    whats ATP?
