S-Line Badge! Will it fit?
Maffy Jan 26, 2005
  1. Maffy
    Maffy New Member
    9
    Hi everyone, I've got a S-line badge which I plan on fitting on my 2003 A3 grille! On quick inspection
    in the dark it looks a pretty fiddly job as you don't seem to be able to get to the back of the grille to attach
    the clips! Will it fit or am I going to have to use sticky back plastic, cable ties and superglue?????????
    /ubbthreads/images/graemlins/confused.gif
    /Maffy
  2. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    dealer or call VAG Part and find tou what the process would be?
  3. nervus
    nervus Well-Known Member
    1,370
    121
    Get a 2003 S3 (or quattro if they are similar) grille badge and prise the 'S3' off with a small flat driver (its just sticky taped on) and then stick the S-line badge in its place with trim tape.
    The S3 one just pushes into place with little metal spring clips, its getting the swines off again which is difficult.
