S 3 Intercooler
scotty_24 Mar 15, 2012
  1. scotty_24
    scotty_24 Well-Known Member
    1,055
    251
    Just looking into intercoolers for my S3, I was looking at the Forge set up.
    Forge also list the intercooler for the Leon Cupra R, at a cheaper price than the one listed for the S3. Could I just buy a one for a LCR? Or are there subtle differences?
    Also open to ideas for other set ups, Ive seen the thread with regards to the wellycooler etc
    Cheers in advance
  2. <tuffty/>
    21,965
    4,239
    FMIC thread in the stickies... :thumbsup:
  3. scotty_24
    1,055
    251
    yeah Ive been reading that, but as for will the LCR one fit my s3 I cant find an answer :(
    cheers tuffty
  4. <tuffty/>
    21,965
    4,239
    Having seen the LCR ones up close and developing 2 intercoolers specifically for the S3 I would suggest going for either a 'wellycooler' or the AH Fabs V2 if you need a larger cooler... the AH V1 and Forge are ok but compromised with the 51mm inlets...
    AH V2 coolers are costing around the £350/£400 plus pipes IIRC but are BT and Hybrid K04 capable...
    The design of the Forge LCR cooler suggests that it won't 'fit' like the Forge S3 one... so begs the question... why spend all that money on something that is a compromise fitment wise when there are products that do fit out there for a similar price... if budget is an issue then the wellycooler is a viable choice as the fitment issues will be present on this as they would the Forge LCR one...
    The Forge S3 FMIC kit is designed to 'fit' its how they have designed it and works well... the AH V1 and V2 are also designed to fit with minimal modification and not have pipes/hoses poking out all over the place... if you are less fussed about the look then tbh get a welly cooler and roll about in the cash you will save as using the std LCR Forge kit will cost more and still have pipes poking out and the race one will be even worse as the LCR has loads more space behind the bumper than the S3...
  5. Take a look at the Wagner Tuning intercooler set up Audi S3 FMIC
  6. Jimgrim77
    Jimgrim77 Member
    957
    21
    The forge kit not cheap but it is a great piece of kit and easy fit.
    Only 2 hour install I reckon.
    Makes a hell of a difference too.
  7. Sam_
    Sam_ Down under
    3,039
    483
    I'm still tossing up between the Wagner and AH Fabs. The Wagner I can get to me for $950 delivered and the AH is $600 before even shipping. Bonus with the Wagner is no cutting (I think) and it's a kit so no faffing around sourcing hoses etc and it's already painted black. That's worth $350 extra to me?
  8. sportstractor
    sportstractor Chugger
    2,709
    There's quite an epic sticky on the subject...
    For me, I found the toyo cooler (aka wellycooler or kevcooler, no affiliation to the 'tufftycooler') was the best value, everything worked out under £200, just have to cut the crash bar yourself and make the brackets then everything else is plain sailing!
