RUSTY wing
dale86 Nov 10, 2012
  1. dale86
    dale86 Member
    438
    15
    Hi all as to common knowledge on the A4 b6 rusty front wings I was just pondering if anyone had used non original audi wings to replace theirs with As I phoned TPS for a price on a wing and it came in at nearly £200 OUCH. Any info would be greatly appreciated on how the fit and quality of non original wing are as my car will be making a trip in to the bodyshop soon and i dont wanna pay that kind of money then painting and fitting on top of the price of the wing cheers.
  2. dpbayly
    dpbayly Member
    391
    Sprayed and fitted mine myself last week
    In booth:
    Ripped apart:
    I got it from euro car parts around £50 they called it OEM, it is a great fit.
  3. dale86
    dale86 Member
    438
    15
    Great stuff mate ill be ordering one of those up straight away thanks.
  4. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,217
    161
    Have you seen the prepainted ones on ebay?
  5. Inertiauk
    Inertiauk Active Member
    574
    29
    I'm shocked to learn this is a problem, I thought the cars pannels were aluminium.
  6. dpbayly
    dpbayly Member
    391
    I know i was shocked to find mine had gone so bad and at first i thought it had gone due to a bad repair but it wasn't till i stripped it that i discovered the real reason why it had gone, it was due to a build up of mud in the back of the under arch lip at the back and in the base where it meets the side sill and this mud had been holding water and rotting it out from the inside out.
    Here's where mine went:
    jimmetal84 likes this.
  7. SL11CKK
    SL11CKK Active Member
    697
    Wouldn't getting it repaired be more economical then getting a new wing as you're going to have to get it painted regardless.
  8. dale86
    dale86 Member
    438
    15
    Yeah thats exact places where mine went and I had a4 1.8t before my diesel and both went on that had it painted and six months later came back through spoke to numerous body shops and the aaid would always eventually return so this is why am going down new wing route.
  9. dpbayly
    dpbayly Member
    391
    Rust is a nightmare especially when its rotted from the inside out the only way to do a permanent repair would be to cut out the effected area and welding in fresh metal, as a result the work involved makes it cheaper to replace.
    If it was light surface rust due to say a stone chip then you could grind it back and probably go back deep enough to rid all the rust but like i mentioned in the case of our front wings the problem starts out of sight on the inside of the wing and goes right through to the outside.
  10. vr6gordy
    vr6gordy Well-Known Member
    2,807
    187
    i been thinking bout this common problem for ages and came up with an easy fix so after your new wing is in place to stop this happening again silcone the plastic arch liner to the body of the car so then no muck can get in and rub on the plastic onto the metal
  11. quattrojames
    14,050
    577
    Mine have gone in the exact same place. You might also get a shock if you took a door blade off and looked under there...
    A8's are, A4's are galvanized.
  12. vr6gordy
    2,807
    187
    they go rusty cos **** sits on the egde of the plastic liner and then rubs on the metal so it rubs so in time it works it way at the paint and galvo then will go rusty
  13. AndyT_uk
    AndyT_uk New Member
    19
    Are there any guides about for how to replace the wing? I need to do both of mine soonish as they've both got bits of rust in the same places as you guys have found.
  14. Funkyfin2000
    Funkyfin2000 Member
    489
    Yeah mine need doing too, a guide would be good...and whats this about pre painted on ebay, anyone had these?
  15. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    My non-oem wing and bonnet are already rusting in a few places, and they're only about 18 months old :( (replaced due to a crash, not because they were rusty)
    I'm very tempted by oem when I replace them as my other wing is still original and absolutely fine.
    My rear off side arch has started to go too, which really sucks as they're not exactly easy to replace like the fronts.
  16. Jama665
    Jama665 Member
    202
    I was lucky someone reversed into mine so got it sorted for the privilege of being parked in the wrong place at the wrong time
  17. Chrisavant
    Chrisavant Member
    42
    Mine has done exactly the same both sides, quite symmetrical, from the highest point forward to the very front. I've had the car from new and tried to claim under Audi's anti perforation warranty. They were very hard nosed and said the warranty only covered corrosion coming from the back and not from the face. I argued that as it was symmetrical, and there were no stone chips, this was from the back and was not external surface rust penetration. I said I knew it was abrasion between plastic liner and wing grinding off the galv, but they simply replied to say if I was not satisfied, I should employ a paint specialist to prepare an expert report. They even provided a suggested specialist! But as this was going to be almost as expensive as repair, with no guarantee of success, I didn't progress. They are good cars, but not as wonderful as the image they project.
  18. dale86
    dale86 Member
    438
    15
    Had my wing done im fairly happy with the fit mine was purchased from euro car parts and my painter fitted a pair to his a4 last year and said he knew theyd rot aggain eventually so painted the inside of my wing too to try and prolong the life of it. I also know what you mean about under the door trims quattrojames as ive recently also fitted door blades my fronts were unmarked like new underneath after cleanig all the build up of dirt off though lol but one of my rear doors has a bubble underneath and now I know its their itl bug me ha ha. Also I cnt see the prepainted wings on ebay been a very good color match as the shade on mine was slightly out as it was painted off the car im going to have to get it blended in a few weeks.
  19. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    The OE quality wings from euro car parts are £132, they do a cheaper version for £90. The OE wings from Audi are £186. I would go with the Audi wings as they will be better quality and last considerably longer.
  20. dpbayly
    dpbayly Member
    391
    Nothing wrong with my OE euro car parts wing I fitted it was perfect fit and the underside was waxoyl'ed before fitting so that will certainly last with its built in rust inhibitors, mine was £50 + vat but im in the trade
