rusted hub bolt has no edges!! urgent help!
jcb Oct 25, 2011
  1. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    have started to sort my rear bearing but the bolt is well rusted and there is nothing to get hold of.
    I dont have a suitable 12 point or spline bit to hammer in and was thinking if I remove the wheel I could weld a nut/bolt on the end of the stripped hub bolt.
    never fecking easy!
    question:
    any other options?
    if I do go down the welding route do I really need to disconnect battery/alternator/ECU or any/all of them?
  2. Bradderz_1988
    3,899
    230
    Air chissel and a pair of ear defenders ! Lol
  3. aragorn
    17,872
    686
    i dont think a hammered in spline bit would work anyway, its just too tight.
    Stick your 14mm hex in the hole and weld it on, then undo.
  4. jcb
    4,132
    13
    so what do I really have to disconnect to weld?
  5. aragorn
    17,872
    686
    The hubs surely electrically isolated from the rest of the car anyway? its all rubber mounted...
  6. aragorn
    17,872
    686
    Saying that, its bolted to the diff, which bolts to the shell.
    Unplug things if you want, i've welded bits before and didnt bother.
    I cant see how it can cause a problem, its a completely seperate circuit to any of the cars electrics.
  7. Broken Byzan
    13,235
    464
    Ive not bothered, not had any probs so far.
  8. jcb
    4,132
    13
    fecker is off.
    big hammer, disposable bit and a fecking long bar!
    had to get assistance on the bit
  9. aragorn
    17,872
    686
    good stuff!
