Running Rich or Lean???
Rallyman Feb 10, 2006
  1. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Im running a new type of LPG system on my 2000 A4 and doing some development work, Im getting the following error code up after a long drive:
    00561 - Mixture Adaptation
    14-00 - Adaptation Limit (Add) Exceeded
    Is this meaning that it is running too weak and it has reached the limit of adding?? or otherwise?????
    Many Thanks
    Michael
  2. madvw
    madvw Active Member
    2,489
    there was a good post here not so long ago detailing the differences between Mixture adaptations and trim. Have a quick search.. one is to do with idle mixture, the other is to do with accelerating mixture.
  3. Broken Byzan
    13,237
    465
    Slightly weak, mine was fixed after changing some vacuum hoses and a new MAF, not sure which one did it, but it's gone now,lol
  4. Rallyman
    213
    Ok, so to start off with I will try and run either bigger injector jets or increase the pressure on the rail.
    Michael
