Running Lean
Danny Cawsey Jan 11, 2013
  1. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Hi Guys i put my S3 on the dyno today to see what power it is making and found out it was very low on power and running extremely lean, Any ideas as to what could be the problem? Fuel pump knackered?
    Here are the Graphs.
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    checked the pressure hose to your FPR?
  3. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Yep checked that, seems to be fine.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Checked the FPR for gunk ?
    It may be a tired pump, i put an inline one in to help out...
  5. <tuffty/>
    21,899
    4,206
    If its a tired pump then an inline pump is not a fix... do you have logs to support the AFR on the dyno graph? need to check requested vs actual... could be the maps actually asking for that AFR...
    Its most likely the pump in which case a new one is required but would need to see the AFR logs from VCDS to confirm...
  6. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Cheers Tuffty, i dont have logs as i dont have access to VCDS, unless anyone in Bristol has VCDS and wants to log it for me tomorrow? :)
  7. <tuffty/>
    21,899
    4,206
    Might be worth taking a trip up to Bill's then as you are just down the road... J13 M5...
  8. Danny Cawsey
    Danny Cawsey Cawsey
    516
    I was just thinking that, i also have an oil leak so its prob not a bad idea. Ive got a free day tomorrow if bills likely to have space.
  9. <tuffty/>
    21,899
    4,206
    Not sure what his schedule is like but I suspect there would be easily time for a road log if nothing else as it will be evident fairly quickly whats going on
    May see you tomorrow then...
  10. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Ok then mate ill pop up tomorrow, whats a good time?
  11. <tuffty/>
    21,899
    4,206
    Best bet is to give Bill a ring just after 9am mate...
    http://www.facebook.com/Badger5Ltd
  12. Danny Cawsey
    Danny Cawsey Cawsey
    516
    So i went to Bills today and did a couple of runs on the dyno to find out it is the fuel pump that was knackered,
    Cheers Tuffty and Bill for checking my car and nice to meet you both.
  13. badger5
    9,603
    2,061
    you're welcome
  14. Gizmo20VT
    Gizmo20VT Active Member
    294
    I have the same problem, saving for oem intank pump... Pretty costly!
  15. badger5
    9,603
    2,061
    VDO listing at £200 on ECP website currently
    VDO Fuel Pump Part No.: 441441110
  16. 666markyboy
    666markyboy Well-Known Member
    1,240
    60
    Don't you just love this forum ..... great work guys :respekt:
  17. <tuffty/>
    21,899
    4,206
    They appear to be doing 20% off too...
  18. Danny Cawsey
    Danny Cawsey Cawsey
    516
    Cheers guys.
