Running Issue on my Leon Cupra 180
scotty86d May 5, 2012
  1. scotty86d
    scotty86d New Member
    14
    Took the car to a rolling road Thursday 161 first run, 151 second. It was pinking lots (quite shocked at that)and backing the timing like mad and dumping fuel in.
    It's had a recent maf, service inc all filters. I did an mot emissions test and it flew through. Before the dyno run it would not go above 125 and when you backed off it accelerated slightly-ties up with the timing findings( I know 95 will make it back off a touch but 30hp ?!? It drove no differently on vpower). It is flat in high gears under load
    Any ideas that could assist in me making my car safe to enjoy I will be most grateful however. I'm thinking possibly a blocked cat? Excuse for a downpipe at least.
    No fault codes on vag com, it is getting the requested boost by the looks of the logs
    Also when cold ie just started with the lights on, the lights dim and revs drop every 5 seconds or so for a split second and power drops momentarily too. This happens for maybe 1 or 2 minutes. Alternator?!?
    Thanks in advance
    Scotty
  2. scotty86d
    14
    1st problem is down to compression in 4th cylinder being 60 odd down
