Run Battery Flat - ESP Fault
SCFC_Messiah Jul 4, 2012
  1. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    Fitting lowering springs today and like a muppet left keys in the ignition with the radio on for too long. Went to start the car now and the battery is flat. Getting a warning message to say there's a fault with the ESP
    Will the warning message disappear after I jump the car? Or is the fault code going to need to be cleared £££?
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Yeah it will go out
  3. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    Thank you kindly, sir :)
    It didn't go out initially, but after driving the car for just a few meters the ESP and Power Steering fault lights disappeared
  4. Old-Boy-Racer
    Old-Boy-Racer Guest
    This usually happens whenever the battery is disconnected. The ECU loses its sense of the steering's position - specifically its limits left and right. This causes the ESP to malfunction as it needs to know exactly where the wheels are pointing. Hence why the steering light and ESP fault are indicated. It can sometimes be cleared by turning the wheel lock to lock a few times. My mechanic told me to find a largeish car park and do several full lock turns left and right. It usually clears itself before I get there LOL:racer:
  5. Vertigo1
    Vertigo1 Well-Known Member
    3,633
    726
    I had to disconnect the battery a few times on my last car and basically half the electronic systems have a fit when you first start it again and take a few hundred yards of driving to sort themselves out again :)
