Rumbling Noise - rear diff?
NicA4V6 Mar 24, 2006
  1. NicA4V6
    NicA4V6 New Member
    14
    Hi, newbie here - I've just picked up an A4 2.8Q (1997), and its making some interesting noises from the rear. I can liken it to the noise my old audi coupe quattro made when the diff locks were engaged, however I'm not sure whether the A4 has diff locks or not. Does anyone have any idea what may be causing it? It only happens when approaching full lock when driving forward at slow speed.
    Any ideas would be greatly appreciated.
    Nic
  2. NicA4V6
    NicA4V6 New Member
    14
    Help? Anyone? I've booked the car in to the garage this Thursday so I'd like if possible to go armed with a couple of ideas. When they find out what it is I'll post the conclusions up here.
    I've done a little more investigating and it seems to make the noise in forward and reverse, but does it mostly when I use the throttle (even gently) and full steering lock. When the car is allowed to drive forward / reverse just on tick over (its an auto) the noise is greatly reduced.
    Don't know if this will help spark any ideas but fingers crossed.
    Cheers for any help
    Nic
  3. RichA3Turbo
    5,089
    Wheel bearings?
  4. NicA4V6
    NicA4V6 New Member
    14
    I don't think so. It only does it when on full steering lock and sounds like its coming from the rear of the car. Also, there is no noise when normal road driving, only on the tightest of round abouts.
  5. RichA3Turbo
    5,089
    Ah ok. The quattros tend to make quite a rumble at teh back when turning on full lock... Ive experienced this in 3 A4/S4's so that is normal... But never on roundabouts....unless you mean those spots in the road.
    Rich
  6. NicA4V6
    NicA4V6 New Member
    14
    Thanks Rich, It only does it on my local tesco's roundabout which is rediculusly small, normally its fine - so hopefully its nothing then if its normal quattro type noise. I'll let you know if it turns out to be anything.
    Nic
  7. shagga
    shagga Member
    153
    I had something similar on mine and I was told by a few Audi dealers it was the tyres grabbing but that was the front. Since I've had my suspension upgraded and geometry check it has stopped..?
    Hope it helps.
  8. NicA4V6
    NicA4V6 New Member
    14
    Shagga, a geometry check is next on the list as it is pulling slightly to one side anyway so I know the tracking is out, but it definatly seems to be coming from the rear. Its in the garage at the moment anyway so will see what they say!
  9. shagga
    shagga Member
    153
    Good luck mate
  10. NicA4V6
    NicA4V6 New Member
    14
    Well, got the car back. The guy at the garage couldn't find anything and also has a quattro that makes the same noise. He also checked with his mate at a main dealers and he confirmed that it wasn't anything to worry about.
    So £30 quid lighter but at least my brain can now rest easy.
    Cheers for the suggestions,
    Nic
