RUBBISH MPG!!! HELP
Ellisa3 Aug 22, 2011
  1. Ellisa3
    Ellisa3 New Member
    14
    Hi guys, i have an Audi A3 TDI 140, I put £25 in and that gets me about 4 Gallons, im lucky to se 125miles, i drive about 80% around town and 20% on short dual carridge ways.
    Ive changed the air filter, im going to change the fuel filter tomoz
    cant see these makin much difference
    really stressed, i bought this car for economy, i was getting same mpg in my Megane F1 :-(
    Help
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    77
    Hole in your tank?lol it sounds silly but deisels arnt great round town, i get abot 30.7mpg from a 1.9dci citroen.
  3. Naj
    Naj Member
    75
    Considor a remap geared towards economy. I got a performance remap but it at least added 5mpg more. Around town, driving sensibily I can get 40mpg minimum.
  4. Ellisa3
    Ellisa3 New Member
    14
    as standard these should be getting 40mpg around town
  5. Ellisa3
    Ellisa3 New Member
    14
    anyone else help lol
  6. Naj
    Naj Member
    75
    The engines got some kick as you know so I could be getting 35-40mpg but rev it passed 2500rpm for a few secs and the mpg comes tumbling down. Before you look at problems with the engine, see if your driving habits have any effect. Gear up before 2000rpm (torque can handle it), cruise in 5th gear when doing 30mph and general anticipation to avoid bringing the car to a halt too often.
  7. PilotAudi
    PilotAudi New Member
    2,352
    479
    Sounds about right, think yourself luck its not a Petrol! Do you get 40+ on a run?
  8. Ellisa3
    Ellisa3 New Member
    14
    getting about 38-40 on a good run :-(
    i can hear bit of a hissing noise by my drivers wheel when idleing, kind of sounds like an air leak, soon as i rev the car it goes fro a minuite or 2 and then comes back, confused :-s
  9. Naj
    Naj Member
    75
    I'd calculated you got about 31mpg from your first post but 38-40 is normal.
  10. Ellisa3
    Ellisa3 New Member
    14
    could it be a boost leak?? noise goes tho wen reved lol head work, also very slight air leak noise coming from pipe at the very top of my tandem pump, tandem pump is just above the water flange if this helps
  11. Sheikh
    Sheikh Member
    654
    20
    The idea's to keep it between 1500-2000rpm whilst only keeping your foot on the accelerator very lightly... get about 50mpg around town like this. No point trying to keep it below 1500rpm as the engine seems to struggle too much and ends up using more fuel!
  12. Ellisa3
    Ellisa3 New Member
    14
    thas wa i been doin lol, iv motherd this car every day lolol, really dissapointed with it
  13. Ellisa3
    Ellisa3 New Member
    14
    ive managed to get 101 miles off quater of a tank, my partner had 150 miles off quater in a golf tdi
  14. Sheikh
    Sheikh Member
    654
    20
    The only thing i could think of is to give the car a full service (filters and oil) and check the boost hoses for any leaks?
    Yeah i just got 140miles from a quarter tank. (non sensible driving)
  15. Ellisa3
    Ellisa3 New Member
    14
    boost leak im thinkin :-(, can this effect mpg that much
  16. nally
    nally MPG the new BPH
    2,104
    34
    i can get up to 60mpg in mine.
    50 % a roads
    10%motorway
    40 % town driving
    £30 gets me 230 miles
  17. Sheikh
    Sheikh Member
    654
    20
    Try giving the car a good thrashing, then reset the mpg meter and go on a short sensible a-road run and see if it made any difference.
  18. Harrelson
    Harrelson Member
    173
    diesels are **** around town. my 1.6tdi gets 39-44 mpg in town but cruising is another story
    2 weeks ago drove with a friend to nurburgring, filled up in bristol and when i got to the nurburgring i had 1/4 of a tank left (550miles covered). this was cruising at 85mph min all they way and in germany it was 110+mph for about 120miles!
    i think i can tease 800+miles from a tankful doing 65mph all the way
  19. Ellisa3
    Ellisa3 New Member
    14
    this is the mpg i wanna see :(
  20. flying oyster
    flying oyster flying oyster
    563
    27
    800 miles from one tank god im doing something wrong!!!!
  21. zedzo
    zedzo Member
    149
    his got the new engine. you aint getting any of that with urs, think he also has a bigger tank. weve got a new engine touran an can do a trip from london - manchester on a quater tank 240 miles :jump:
  22. Ash187
    7,495
    744
    On a full tank in my 140 I get just over 500 miles. That's not an average, it's the actual mileage display as I like to reset it every time I fill up to make sure my economy is good. That being said I know the car is capable of more so after my next service I am looking to get the car mapped and would be expecting a good increase.
    What most say is true though, on motorways diesels are great and I can get up to 60mpg on the motorway (usually it's around 50mpg) but in towns I need to make sure I'm not booting it off traffic lights and generally ragging it to get a reasonable 40mpg.
    One thing I do though is try to drive the car in a higher gear as that helps with the mpg, so I can cruise at 30-35 mph in town and leave it in 4th gear and only really tap the accelerator when I need a little bit of juice.
  23. nally
    2,104
    34
    I dont really drive eco, but i dont rag my car either.
  24. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    But doesn't cruising in high gear at low speeds/revs cause more wear to the DMF (more vibrations to dampen from the engine at low revs) and clutch (accelerating in high gear from low revs wears the clutch) ?
  25. Ash187
    7,495
    744
    I only drive in higher gears when i am just cruising in town... not the constant stop and go traffic light situation but more of a easy moving and flowing traffic where i dont need to touch the clutch or gears.
  26. JNP
    JNP Member
    102
    MY BKD Diesel does about 600 a tank which I fill every two weeks or so.
    This is quite a decent drive though with not much stop start and the car is also mapped.
