Rubbing Plastic under arches
sam4191 Aug 9, 2009
  1. sam4191
    sam4191 If In doubt, Flat out!
    417
    Hello!!
    Maybe I am being silly here, but since I lowered my car, My wheels have been rubbing the plastic arch protector things. They're not touching the wings at all. I'm just wondering what I can do to stop the scuffing. My dad has mentioned the obvious (make the front slightly higher), but I don't want to do this as it's only the plastic.
    I'm also thinking that just removing the plastic liner will be stupid, and won't do the car any good.
    Just wondering if anyone else has had this problem and cured it??
    For referance I am running 225/35/19.
    Sam
  2. Siena
    Siena Active Member
    2,626
    I'd go with your dad's suggestion, and RAISE the front a bit.
    Other option is to run 18" wheels, as 19" versions are a tad big for a B5. In view of cost, I'd say it'd be cheaper to raise the front.
    If you're tempted to start chopping chunks out of your plastic liners, you might as well have none fitted, a no-brainer in my opinion.
  3. sam4191
    417
    Hmm... Ok, looks like I'll have to do what I hate... Admit he's right. lol!
    Yeh, to be quite honest, it does seem very sensible, thought as the car is at the moment, it sits perfect on the wheels. It only rubs when i take a corner too quick, or hit a large bump.
    18"'s are tempting... feel like a change too tbh. Don't have the money to waste if it doesn't cure it.
    Will put std. wheels back on tomorrow and run them for a couple of days... see what happens.
    Thanks for the comment! =D
  4. Geeman
    Geeman Low Life
    1,318
    You got a pic of it as it is...?
    40mm doesn't sound a lot to have lowered it to cause this problem.
    Mind you, although I'm running VERY low, I'm only on 215 tyres.
  5. jcb
    jcb Active Member
    4,132
    13
    get some decent suspension and it won't roll as much.
    how low are you?, can you get a finger inbetween the tyre and arch pushing it in from the side horizontally?
  6. Geeman
    Geeman Low Life
    1,318
    LOL - I can't on mine!
  7. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Sam,
    Slightly off topic but what is an "unrestricted airbox" :uhm: Sound's interesting.
  8. jcb
    jcb Active Member
    4,132
    13
    open it up and remove anything that doesn' make up the outer casing
  9. gaz71
    286
    :uhm: The only things inside my airbox are the MAF unit and inlet (which secures the MAF unit in place). Any pics?
  10. sam4191
    417
    I do, but I need to update that... It's lower than 40mm now.(on Jamex(cheap!) adjustable coilovers) Just put the std. wheels back on. Ride is so much nicer, corners a bit floppier (tyre walls), Importantely doesn't rub! =D lol!
    Yeh, this is true... I dont have much money though:(
    I can get a finger and a half in. Too high IMO! lol!
    HAHA! It's my gay way of saying cold air flow bit on top is off and has a very large hole in bottom of air box. lol! :lmfao:
  11. gaz71
    286
    Ah I see. That makes perfect sense now:jester:
