Rubbing now lowered.
Cviji Oct 4, 2007
  1. Cviji
    Cviji Member
    58
    Just finished lowering my A4, 60mm front and 40mm back. The front is absolutely fine, but the back tyres are rubbing on the lower plate of the shocks, is the only way round this spacers? where can I get some quickly that will widen it around 10-15mm? each side? Has anyone else had this problem? The tyres are 235/45/17s.
    Thanks.
  2. andybnwc
    andybnwc Member
    752
    10-15mm each side thats a bit much , must be wrong offset to need that much , i have run 235,35,19s very very low with no problems
    maybe try 5mm each side max
  3. Randomjim
    Randomjim Active Member
    2,752
    You should be on 215/45/17 i think, notice you have b6 wheels which have a higher offset that the b5's. Set of spacers should do the trick.
  4. Cviji
    Cviji Member
    58
    I think the main reason its rubbing is the lower plate on these shocks is quite abit wider than on the old shocks, I think ital need more than 5mm though. Ive ordered some hub centric 15mm ones and ill try those and see what happens, you are right it might be too much. Will it look odd if just the rears have spacers?
  5. PaulJC84
    PaulJC84 Owner
    2,921
    17
    I have 20mm ones on the rear of mine so you should be fine with 15mm mate.
  6. Cviji
    Cviji Member
    58
    Ok thanks, Do you not have them on the front? Can you not tell the difference? I should have them in the morning so will stick em on and try them.
  7. PaulJC84
    PaulJC84 Owner
    2,921
    17
    I have 15mm on the front.
  8. joost
    joost Active Member
    1,169
    Mine rubs but only when hoofing it round a corner and only on one side :think: . It doesn't do it quite so much now I've got the 18s on as it did with the 17s (the 17s were the same alloys & tyres as you Cviji - the B6 'Star' wheels).
    What's even more confusing (to me anyway) is that the 17s were ET45/7.5J and the 18s are ET42/8J so I would have thought that the 3mm difference in offset would be almost cancelled out by the difference in J. Or am I just being thick?
  9. PhilR
    PhilR One Ate Tea
    332
    If i had read this earlier i could have saved you some money as i have a pair of 15mm FK bolt to hub spacers for sale
  10. Cviji
    Cviji Member
    58
    So The B6 wheels I have are offset of 42 and The B5 wheels are nomally 35 yes? So what would this equate to? a 7mm move into the wheel arch with the B6 wheels? If I fitted some 17's with offset 35 and 235/45/17 tyres they may solve the problem without the need for spacers if the 7mm is enough to clear the shock. Am i right?
  11. joost
    joost Active Member
    1,169
    If you fit some wheels that have a 35 offset you should be laughing.
    If your B6 wheels came off a cabriolet like mine did, they'll be 45 offset, the original 15s I replaced were 45 offset too. The 18s I've fitted are 42 offset, but since they're slightly wider it's cancelled out any clearance gain I'd got by fitting a lower offset. Apparently, the B5 should have between 35 and 45 offset wheels but I'm sure someone will correct me soon enough if that's not the case!
    To be honest, the 18s I've got on now weren't even supposed to be going on - they didn't fit my mate's A6 so I sort of inherited them!
