rubber seal around ariel base going
tj1978 Feb 17, 2007
  1. tj1978
    tj1978 MRX
    93
    Hi
    my a3 quattro I have noticed after buying it that the rubber band seal around the base of the bit where the ariel screws in, half of it has come away and the rest is easy to peal off....
    Get I get this part from an audi garage and fit a new one on myself ?
    If so does anyone know the part number ?
    Thanks and regards
    Tim
  2. S3Steve
    S3Steve Active Member
    1,621
    20
  3. tj1978
    tj1978 MRX
    93
    thanks mate
    so its the roof ariel repair kit....
    Do i just pull off the old seal and then assume the new one just pushes in to place and it a tight fit ?
    Regards
    Tim
  4. S3Steve
    1,621
    20
    You have to take the roof lining down at the back of the car, you then undo the nut that secures the aerial base to the roof, and take the aerial cable off. You can then lift the the aerial base off the roof and remove the old damaged seal, and fit the new one into place. I found a bit of wd40 aids getting the new seal on to the base as its quite a tight fit. You can then refit the aerial base to the car.
  5. tj1978
    tj1978 MRX
    93
    damn, that seems like a lot of work just to fit a new seal !
    Is taking the roof lining off inside the car a tough proceedure, I dont want to make the car worse through my lack of experience.....
    Cant I just fit the seal externally by pushing it down over where the existing seal was :O(
    Thanks for your help on this
    Regards
    Tim
  6. S3Steve
    1,621
    20
    You have to take the aerial base off to fit it mate, its definately worth the effort, remember the seal is stopping water leaking into your car through the roof. Im sure if you take your time you will be fine mate.
  7. steve1975l
    steve1975l Member
    595
    Can't you get to it from the rear light?
  8. 1ndy
    1ndy Member
    60
    yes you can get at it through the rear light. Needs nible fingers though!
    PS: buy it from VAG Parts - your local dealer will try and sell you the whole aerial (£130+) I rang them a few months ago and politely told them where they could put the WHOLE aerial!!!
  9. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
  10. Ed
    Ed Member
    193
    Mine is falling to pieces aswell. So will be replacing it soon.
    I presume its not too complicated taking down the roof lining...?
  11. tj1978
    tj1978 MRX
    93
    If any of you have the time I would really really appreciate a guide on how I attempt to take the roof lining down (dreading the thought)...
    Thanks loads
    Tim:scared2:
  12. colinra
    colinra Member VCDS Map User
    91
    i replaced the whole base with a part from the stealers at about £30 iirc. i got the one from vag parts first and didnt like it. you dont have to take the whole lining down, just a small part at the rear of the rear light. its pretty straight forward.
  13. tj1978
    tj1978 MRX
    93
    When you say the rear light, do you mean the rear brakelight at the top of the window, that area ??
  14. colinra
    91
    no mate, the courtesy light above the rear seats
  15. jpda4
    jpda4 Member
    129
    21
    drop the headlining light down and nut holding aerial in place should be in front of you
  16. Poppy
    Poppy New Member
    Wow, thought it was only me with this problem, thanks for this post you just saved me some cash.
  17. Aky
    Aky Aky
    1,512
    Could you just not squirt some black sealant into the gap??
  18. DPM
    DPM Site Sponsor Site Sponsor
    5,063
    224
    Changed mine last week, stupid damn thing!
