rs6 steering wheel on 2007 s3
djlazyp Mar 23, 2010
  1. djlazyp
    djlazyp New Member
    27
    right i have got hold of a mf rs6 steering wheel with rs6 airbag for my 2007 s3 but the airbag harness does not fit the plug on the slip ring on my car, could someone please tell me what harness i need part no etc
    i tried making the plug fit by clipping of some bits which were stopping the plug from going on but when plugged in the horn does not work so im sure i need a new harness thanks
  2. luke1987
    luke1987 Air Ride is for Ballers!!
    610
    73
    Give N8 a shout mate, he's already done this mod ;-)
  3. evocos
    evocos Member
    512
    9
    And so has Matt Andrew,i would ask him,he is the technical man
  4. N8
    17,163
    718
    Ask Matt, he's the brains of the operation, I'm just the looks :slap:
  5. evocos
    evocos Member
    512
    9
    :lmfao:
  6. N8
    17,163
    718
    :laugh::laugh::laugh:
  7. djlazyp
    djlazyp New Member
    27
    right managed to rewire the old harness so it all fits and works for now but the new steering wheel has mf which i didnt have before will it work when i get the new harness or do i need a new slip ring etc?
    my car has cruise control if that makes a difference think i read somewhere it does? thanks
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you may need a new steering ecu, is your car a dsg?
  9. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    I would not reccommend that has the wiring is different, it may cause an airbag malfunction
    with assistance
    Jules you are fairly technical, metal to metal is ok isnt it
    and the detailer
    You need to check which ECU you have, either with vagcom or looking at sticker on module, the car will need coding for multifunction. some modules only do cruise. I remember the wiring been different on the rs6 multifunction.
    The best thing to do which i would do would be to order the wiring loom from audi for a S3 with a flat bottom wheel with MF (about £20 IIRC). This will ensure you get the correct wiring as you dont want a airbag malfunction
  10. N8
    17,163
    718
    :salute:
  11. djlazyp
    djlazyp New Member
    27
    Does anyone know the part number for a mf airbag harness as I rang Audi today and they said I need a part number and also they tried saying that it comes as a set with slip ring?
  12. smudge_don
    smudge_don Active Member
    2,944
    From watching NHN do mine, you need a new slip ring, new module and VagCom to code it all :)
