rs6 non-start
murran Oct 18, 2012
  1. murran
    murran Well-Known Member
    1,545
    39
    got an old twin turbo rs6 avant in at work "bcy" engine. cars been stood a few weeks, was running fine before hand. it had a flat battery but wouldnt start on jumping it.
    engine cranks but wont fire.
    four fault codes.
    three fault codes to do with the throttle body, p1545, p1558 and p1579.
    and one ecu faulty code p1604.
    no signs of water ingress anywhere inside or in the engine ecu box.
    weirdly the cooling fans are also running full chat with the ignition on. pulling the 5amp fuse for the fan ecus under the drivers kick panel stops them running tho.
    on cranking theres no live to the coils and the ecu isnt giving out the switched ground to click in the fuel pump relay. but activating it with the power probe manually on cranking doesnt make it start either.
    ecu main relay is working and ive checked all lives/earths to the ecu.
    any ideas guys?
  2. murran
    1,545
    39
    i say old rs6, but its an 04 plate btw.
  3. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    Have you tried pulling the battery and leaving for 30 mins?
    Reason being my friend had a similar issue with his R32 when he swapped over his battery, he had a whole range of dash lights on too.
  4. murran
    1,545
    39
    it was removed overnight for charging the day it came in.
    no updates as ive not had chance to look at it again since thursday.
  5. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    527
    40
    Was it brought in for this reason or was there another fault?
  6. murran
    1,545
    39
    it was brought in with this fault. battery was flat when the customer tried starting it after it had been parked up for six or so weeks. customer tried jumping it to no avail. was recovered in.
  7. Broken Byzan
    13,244
    468
    As stated in other thread ECU fried
  8. AlexGSi2000
    1,464
    199
    Thats not good! - at least the customer is to blame though...
    Would have thought the ECU would have some kind of fused protection? - obviously not...
  9. murran
    1,545
    39
    thats just it tho the car/ecu has fuses to protect it from such things. and ive replaced fuses on other audis that have blown from incorrect jumping procedure. non of these have blown.
    been busy today and still not had another chance to look at it again.
    on the plus side i diagnosed a dhrc fault on a 59 plate a5 and fitted and adapted a new suspension height sensor today amongst other jobs.
  10. murran
    1,545
    39
    been checking out the throttle body faults, being a cause of it not starting.
    as with the throttle unplugged when you clear the codes you get back different codes to the above; "potentiometer 1 + 2 open circ." and "basic setting not performed" (which is one of the ones in my opening post). but the ecu internal fault p1604 isnt there.
    car still doesnt start with the throttle body unplugged, but if you cycle the ignition on and off once youve unplugged the throttle body.... the 5v to power the throttlebody is back. which goes with the throttle body plugged in and the p1604 is back..........
    with it being fly by wire will they normally start with the body unplugged??
  11. murran
    1,545
    39
    its the throttle body.
    i found an old dusty second hand one off a v6 something upstairs at work.
    plugged it on the loom and earthed the body to the engine. put the ignition on and to my suprise it did its adaption and all the faults cleared! and then it started up and idled. rechecked and no faults.
    turned it back off and plugged the old one back in. it did start up but ran very rough on rechecking the codes there was 1 throttlebody fault back along with the p1604. but why it would now start up i dont know? its bloody wierd.
    anyway ive dropped the front panel forward and took the throttle off. theres an expencive new one coming from tps tomorrow.
  12. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
  13. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Ha ha, that's mint. I know that tunnel, it's on the A55 in North Wales. It's where Richard Hammond tested the DB9 cabriolet on Top Gear and where I regularly thrash my VTR SP1. Great acoustics :eek:)
  14. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,554
    896
    Thats class that is. Reminds me of an old video of a massively tuned RS2. German guy was going on holiday with his family and 2 dogs in the boot. The car was fully loaded and as they overtook a Porsche 911 on the autobahn after toying with it his kids started waving at the Porsche driver much to his embarassment.
