RS6 alloys question
Mike.M May 25, 2004
  1. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Thinking of getting some RS6 alloys for my car from Rochford tyres.
    They have et35 (mines et32) which is almost perfect for my car, but they also offer an et45 for 5x100 wheels..............would this be like having 10mm spacers that are part of the wheel or am I missing the point?
    What you think?
  2. RichA3Turbo
    5,089
    [ QUOTE ]
    What you think?
    [/ QUOTE ]
    Ofset work the other way round. I.e, the larger the number, the closer into the car it is. Its measured from the centreline of the wheel to the hub face.
    ET35 is what i have and are suitable for the S3. ET30 might be TOO far out?!
    Rich
  3. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Offset
    The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
    Zero Offset
    The hub mounting surface is even with the centerline of the wheel.
    Positive
    The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
    Negative
    The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
    If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
    - taken from TireRack.com
  4. Mike.M
    2,477
    169
    Cheers guys!
  5. NWMark
    NWMark Member
    211
    14
    yeah so for example.
    if you have wheels with an ofset of ET35 and then put on 10mm spacers, this is the same as having ET25 wheels.
    Mark
  6. scoTTy
    scoTTy Active Member
    1,962
    It might look nice filling the arches more but don't forget the extra load on the components e.g. bearings etc.
  7. richy
    richy Member
    892
    the 45 is for the new shape A3 i got the rs6 in the 45 and fit good on my car but doubt they would fit the previous shape if thats what u have..
