RS4, RS6 or TTRS injectors on 2.0 TFSI BT ?
A4_DTM Apr 23, 2010
  1. A4_DTM
    A4_DTM Member
    115
    I'm building BT kit on my car, it will consist of Garrett GT3076R .82 A/R and custom manifold. I'm not shure what injectors to put in it ? If I stay on stock S3, I will probably see 390HP but that is optimistic because my tuner is tuning on MAHA 3000 with very strong load which probably never happens on the road. He is not very happy with RS4 injectors because they don't disperse gas like S3 injectors do. This is test of them on the "table" LINK
    Are there any other injectors that have same impedance as S3 and that they flow more gas at 110 bar ? For example RS6 or TTRS injectors that are designed for turbo engine ?
  2. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    I thought the S3 injectors were good for nearly 400bhp??
    What kind of power are you looking for in your car?
    There's a bloke on VAGOC whose signature states he has 500bhp but I have no idea what injectors he's running.
  3. A4_DTM
    A4_DTM Member
    115
    Well now it will have about 400hp because I don't want to go over that on stock engine (for now :) )... but I don't want that injectors are working on 99% of their capatibilitys so that is why I would like to install some other injectors
    Inertiauk likes this.
  4. KRL
    KRL Member
    521
    My understanding was that the RS4 injectors should be good. REVO recommend the RS4 and R8 injectors for their stage 3 software on the S3. Here are REVO's HW requirements:
    Required Hardware
    GT3071R Turbo plus installation components
    VAG RS4/R8 spec injectors
    Cold Air intake (from turbo inlet pipe to front of car replacing factory airbox for best gains)
    3.0"Turbo back exhaust without pre-cat and with decat or highflow catalytic convertor (DP comes with turbo kit)
    Uprated or additional Intercooler
    Uprated High Pressure Fuel Pump
    I do not have any experience of the RS4 injectors myself but I know that JonnyC has been running them and not had any issues at silly BHP.
  5. KRL
    KRL Member
    521
    APR do make their own injectors as well which are supplied with their stage 3 kit. They should be good for 500 BHP:
    I do not think they are available separately to the stage 3 kit though.
  6. akash_sky1
    akash_sky1 Active Member
    1,181
    I would have thought injectors designed to run in a forced induction engine such as in TT-RS would be much more suitable. With an engine that has both high compression ratio and pressurized intake I woudn't have thought injectors designed for an N/A would be capable of proper distribution thru more highly pressurized gas.
  7. A4_DTM
    A4_DTM Member
    115
    Just checked with jonnyc, TTRS and RS6 injectors don't fit :(
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    dans s3 (the vagoc one talked about) is running rs4 injectors with over 500bhp
  9. Unitronic
    Unitronic Fear is just a word!
    214
    66
    The information they shared is not correct.
    RS4 injectors outflow the S3 injectors when testing at the proper fuel pressure. Their junior injector test stand is not capable of testing at the correct operating pressure. The formula they used to calculate the flow rates at the proper pressure is incorrect.
    Unmodified S3 injectors are not capable of flowing as much fuel as the RS4 injectors, therefor your potential to make more power on s3 injectors will be lower than RS4 injectors.
    The RS4 Spray patterns is not perfectly designed for the 2.0T FSI and as such has some side effects. The spray pattern is in no way a benefit and in no way makes it a better option. :s3addict:
  10. S3Alex
    10,826
    4,820
    Thread exhumation!
    I agree that the RS4 injectors at correct pressures are capable of flowing significantly more fuel,and those of us running RS4 injectors with big turbos have found them to be capable of over 500bhp,and probably up to 580bhp before they start to hit the limits,after which you need something like a Stg2 Sorensen manifold with extra injectors and off board ECU.
    For sure also,the spray pattern is not optimal,and this is something that APR used to make much of when bashing them,but depsite that,they do work,and there are few alternatives.
  11. grainqey
    grainqey Active Member TFSI Owners Group Team Silver Audi A3 DSG
    565
    172
    43
    Holy zombie undead thread resurrection....
    I've been looking at the new 4.0tfsi V8 injectors and TTRS injectors but nobody seems to have any information on the actual flow rate or spray pattern. The TTRS are supposed to flow 30% more than the S3 ones and I'm presuming they are the correct flow which is fine but I can get a set of 8 of the 4.0TFSI injectors which should be plenty based on what VFS on facebook advertise....
    From facebook, VFS - vag fueling solutions supply the new 4.0tfsi injectors for anything from 400-500bhp and TTRS/RS3 from 500bhp upwards
    Does anybody know anything about this?
  12. S3Alex
    10,826
    4,820
    Rick advises using the RS3 injectors if I remember but best to check with him.
    Mine is using a totally different solution now.
    Inertiauk and grainqey like this.
  13. grainqey
    565
    172
    43
    I'll have to see what Rick says,
    I'm half tempted to swap from my current tuner to Rick when I go big turbo so i'll have to see what he says, not a million miles difference between my current tuner and Rick as I'm only over the woodhead from him!
    Inertiauk and S3Alex like this.
  14. S3Alex
    10,826
    4,820
    I think unless you want something like mine then Rick would be an excellent choice.
    He can get the best from the stock ECU and the various injector and LPFP options.
    Otherwise....one word.
    Syvecs.
    grainqey likes this.
  15. grainqey
    565
    172
    43
    I'd rather stay with the stock ecu but that may end up being a problem depending how mental I go haha!
    I'm only FWD - although my tuner always asks if mine is Quattro when I have dyno runs lol
    I'll drop him a PM about the injectors and see what he says
    S3Alex likes this.
  16. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    RS3 8V
    Inertiauk, grainqey, S. and 1 other person like this.
  17. nil538
    nil538 Active Member
    499
    66
    Hi what's the difference between 8p rs3 injectors and 8v rs3 injectors?
  18. grainqey
    565
    172
    43
    Think it's how they fit in the head
  19. Inertiauk
    Inertiauk Active Member
    574
    29
    Do these plug straight in ? Or do you need a loom / adaptor ?
    Best place to source the 8v injectors ? Which fuel return valve ? (Stock is fine I presume due to upgrades injectors).
    Thanks!
  20. grainqey
    565
    172
    43
    you have to repin (swap) the 2.0 TFSI connectors to the RS3 ones on the loom - the pins are the opposite way round too from what I've been told
  21. scotty2hotty
    scotty2hotty Member
    64
    I'm in the middle of fitting rs3 injectors and have just noticed you mention the pins are the opposite way round? Is this a definite? And I assume they can't go any way round?
  22. george_seamons
    george_seamons Active Member
    323
    86
    They are just a solenoid, so it doesn't matter what way around they go
  23. scotty2hotty
    scotty2hotty Member
    64
    Thanks for your reply and I was thinking it might not matter but still spent over an hour trying to find pictures of the plugs and wires.
    Anyway I got it running this morning so hopefully it's all good
