RS4 Replica Center Cap
CaTFiSH Dec 19, 2003
  1. CaTFiSH
    CaTFiSH Member
    66
    I have a model of replica in which the center cap have a real screw, i think it's the first model that appeared in the market, i want to know if is it possible to adapt the OEM center Cap on this Replica....
    Thank You. /ubbthreads/images/graemlins/frown.gif
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Here's the back of an original Audi Centre Cap. It's totally over engineered as you'd expect, and I had to trim a few of the fins to get it to fit my replicas. The springy bit that holds it to the wheel measures 60mm across, but can be squeezed to 55mm by trimming the spring clip. The overall diameter is 147mm, but you need to have a hole about 130mm to accomodate the lip. You'll have to do what I did, and order one and see if you can modify it to fit the wheel. If you can, then buy the other three.
