RS4 rear sway bar
Dazmo Apr 23, 2010
  1. Dazmo
    Dazmo Active Member
    1,762
    Looking at fitting the RS4 rear sway bar to my S-Line A4 3.0 Tdi 2006
    I found a guide here http://www.audizine.com/forum/showthread.php?225821-RS4-Sway-Bar-Install-Guide
    The part numbers i have found are these:-
    1 x B7 RS4 22mm rear stabilizer bar 8E0-511-409-AM or 8E0-511-409-AL (which ever one is the newer part number)
    2 x Rubber bushings for bar - 8E0-511-327-B
    2 x Clips for bar - 8E0-511-439
    4 x Bolts for rear stabilizer bar - N-101-277-06
    Can you confirm these are the correct part numbers for my car?
  2. stoke_audi
    stoke_audi Active Member
    2,243
    19
    1 x B7 RS4 22mm rear stabilizer 8E0-511-409-AL £57.46
    2 x Rubber bushings for bar - 8E0-511-327-B £2.69 EACH
    2 x Clips for bar - 8E0-511-439 £2.96 EACH
    4 x Bolts for rear stabilizer bar - N-101-277-07 £0.66 EACH
    Dave
  3. Dazmo
    Dazmo Active Member
    1,762
    Cheers dave, do i also need:-
    N 105 281 03 hex head shoulder bolt M10x18 qty 2
    And can you give me a quote for fitting with you please?
  4. Dazmo
    Dazmo Active Member
    1,762
  5. stoke_audi
    2,243
    19
    bolts £0.40 each
    fitting £94.00 + vat
    Dave
  6. Dazmo
    Dazmo Active Member
    1,762
    £110.00 for 15-30 minutes work? So do audi charge £220 per hour labour then?
  7. Dazmo
    Dazmo Active Member
    1,762
    So dave how do i order from you then, can i order the parts and collect them and pay when i collect please?
  8. stoke_audi
    2,243
    19
    yes no problem
    will order so we get thme on thursday for you
    Dave
  9. Dazmo
    Dazmo Active Member
    1,762
    Ok mate, so just to confirm then.
    thats
    2 xN 105 281 03 hex head shoulder bolt M10x18 £0.40 EACH
    Total- £72.20
    Im hoping these are all the correct parts i need!
  10. stoke_audi
    2,243
    19
    ORDER REF : 22236
    DAVE
  11. Dazmo
    Dazmo Active Member
    1,762
    cheers dave,
    can you let me know when its all in please and what you opening times are.
  12. Dazmo
    Dazmo Active Member
    1,762
    Dave can you also order me x2 4B2955425C front wiper blades at £14.80 each for my a4.
    And also add the front and rear mudflaps i asked about a few weeks back, think you said they were £54 front and back for my a4 sline saloon.
    So total is approx £155.00 for all the rs4 stuff, wiper blades and mudflaps
