RS4 intercoolers
Nez Sep 12, 2009
  1. Nez
    Nez Member
    598
    Hi guys I just find a RS4 intercoolers one of them was repaired the drivers side intercooler and both intercoolers have been cleaned and pressure tested and are fine.
    And they guy wants £160 Incl delivery.
    It incls the the shrouds too :)
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    Show off.
  3. s4marsh
    s4marsh Member
    360
    lol
  4. Nez
    Nez Member
    598
    Lol so is it worth it :) and also is the intercooler be fine with higher boost because it has repaired?
  5. Nez
    Nez Member
    598
    Here is some picture of it and by look of the intercoolers I don't like it :(
    What you guys think it looks black is it because of the repair :( or something wrong with them?
  6. s4marsh
    s4marsh Member
    360
    they're black to be discreet, but the side thats mangled looks a bit nasty to me so after the cost of a proper repair and then having to trust them although you'd be putting less boost psi through them than a tuned rs4 would your gonna be looking at £100 minimum to repair i would say so they not so cheap then are they?
  7. Nez
    Nez Member
    598
    I don't like the side of them too :( and I am worried when I go for the RS4 setup then I might get problem with them :sorry:
  8. s4marsh
    s4marsh Member
    360
    yeah if you go rs4 spec new ones would give you peace of mind. you've just got rid of your boost leaks and you know the effect they have
  9. Blue_Thunder
    1,776
    33
    I'd say that's a very good price. I paid over £300 for mine, then had to buy shrouds for an additional £80-90. If they've been pressure tested after the repair then what is there to worry about?
    2nd hand intercoolers are always going to be a bit of a mess. Only takes a few small stones travelling at over 100mph to dent the cooling fins.
    They will still represent a big improvement in cooling over your standard ones, and i'll bet if you take your bumper off you'll find yours are in pretty much the same condition as well.
  10. Nez
    Nez Member
    598
    This is the reply I get from the seller :)
    "Hi Nez
    The intercoolers are in perfect working and have just got general wear on them. Every used intercooler has got wear. I would not sell something that is no good and I can assure you they work as they should with no leaks. I know they don't look brilliant but this is why they are cheap. If you want a mint set you would be looking a lot more than what I am asking.
    Once you receive them I would strongly advice you to get them pressure tested by someone who deals with Intercoolers so you can see yourself that nothing is wrong with them. It should be FREE or no more than £5 to get them tested
    This will give you piece of mind before fitting them.
    It is up to you anyway
    thank you"
    I will go for this as its not bad price :) should I get the pipes with it or I can use my S4 hose pipe kit the one that I bought from ebay :think:
  11. Broken Byzan
    13,237
    466
    It looks to me like the Rad recon service he used repaired and painted/coated them black to look the part.
    As long as the repair was done by a proper place and isn't just a wodge of blue tack then it's a bargain.
  12. Nez
    Nez Member
    598
    The guy says that as been repaired and pressure tested so I have to go with his word and see what happens :yes: any ways I send the money and lets waiting now for it to come :)
    Onething how hard is it to fit them can I do it :think: or as anyone fit it them to their cars and can give me some hands :)
  13. jcb
    jcb Active Member
    4,132
    13
    if they are pressure tested find out to what pressure and get a written warranty (even if it is a month). if he is not willing to do that then walk.
    fins are easily bent back into shape but a repair is going to cost you teh same again.
    would you not be better saving a few more quid and getting some better aftermarket SMIC's? at least they will be new and not repaired.
    forget what brand the RS4 boys use
  14. CraigG
    CraigG Member
    190
    wagner are uprated over the RS4 ones, but are close to 1k with the shiney carbon shrouds.
    CX racing do copies of the wagner items for around 500USD but then you have shipping costs etc to add on.
  15. s4marsh
    s4marsh Member
    360
    there are quite a few custom intercooler fabrication places about and i think you'd get a pleasant surprise at what they'd charge.i'm sure i got quoted about £460 for some locally made. as for fitting them yourself, if your ok taking the front bumper off which is the hardest bit i thought and a few other bit and bobs you'll be ok.someone will soon bail you out if you get stuck but check that someone is local first before you start
  16. jonnya
    jonnya Member
    102
    Mine are for sale as well (not repaired). IC's + shrouds (cut for S4 bumper) 250 ono
  17. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    What state are they in matey? Does the bumper have to be cut out aswell to suit? Would I have to lose the (pretty hopeless) foglights or not?
    Are you going for a FMIC? I looked into it briefly and some kits mean that I would lose the aircon :scared2:
  18. Blue_Thunder
    1,776
    33
    The S4 bumper doesn't need to be cut to fit RS4 intercoolers.
    You don't have to remove the foglights either, but a lot of people (myself included) do to remove the 'obstruction' in the airflow to the coolers.
  19. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    be honest DAN do you use the aircon much?? its not as if we need air con in this country.
    if you lose the aircon then you lose summin that has quite a bit of weight and summin that drinks petrol so losing the AC is a winner in my books. just my opinion though, i could be wrong
  20. Matt82
    Matt82 Active Member
    2,365
    loosing AC? youll save 15-20kg on a car that weighs 1550-1600kg.
    picking peanuts out of dog poo springs to mind! one of the reasons im switching to an s4 is because i want something sensible and civilised, ive grown tired of the bear basics golf gti
  21. jonnya
    jonnya Member
    102
    ICs are fine. Shrouds are cut for fit the S4 bumper profile. You'll need some pipework and
    the lock carrier will need to be trimmed but that's pretty straight forward - I used a
    reciprocating saw. The ad is still in the classifieds I think, more detail in there.
    I fitted a CXRacing FMIC hence these are surplus.
  22. Nez
    Nez Member
    598
    Can any garage fit the RS4 intercooler or do they have to know how to fit a RS4 intercooler into S4 :(
  23. S4twiggy
    1,815
    9
    wot im sayin is if you want to have a FMIC but are worried about losing the AC then thats fine but i think AC is overrated and be honest.....how many people actually use AC in britain, not as if we have boiling summers or roll around in 30degree heat, theres always the windows to go down lol
    if you want FMIC then forget the AC
  24. S4twiggy
    1,815
    9
    try QST around your way, see wot they say.
  25. Broken Byzan
    13,237
    466
    Aircon isn't just for the summer, it helps defrost your windows in the winter too, especially in the rain. I wouldn't be without mine as i prob use it more in the colder weather than the warm TBH
  26. Matt82
    2,365
    i love my old golf so much but im looking to get rid because i want AC. when you dont have it youll realise how good it is :undwech:
  27. jonnya
    jonnya Member
    102
    You don't lose the AC with an FMIC anyway. You lose one very small fan. So far, I haven't
    noticed any difference.
  28. Dan Gliballs
    1,568
    Excellent :cool:
    Yeah, that 430bhp one I twatted on about had those 'Canadian' grilles. Suppose I could do that and keep the fogs for if I ever sell the car.
    I use the aircon very regularly indeed yeah.
    I HATE hot weather!!!! lol............very sensitive to it. I'm a lot calmer in the cool air ;)
    Also, it's not only me in the car. Rachel and my wee boys wouldn't thank me for removing the aircon when we're sitting in endless traffic on the M6, roasting hot July days with a heat-haze coming off the tarmac, faces going from pink to red..............all in the pursuit of a few extra bhp. It's our second family car.
  29. Dan Gliballs
    1,568
    Totally agree.
    This S4 will NEVER end up like my stripped-out Astra.
    And a further point is that generally speaking, removing the aircon would massively limit the market for when I come to sell the car.
  30. Dan Gliballs
    1,568
    Ahh, maybe that's what I read :)
    Your aircon/climate still works as normal then? :cool:
  31. Nez
    Nez Member
    598
  32. Blue_Thunder
    1,776
    33
    The lower hoses for the RS4 coolers are different I think as they are a slightly bigger diameter. Not sure about the top ones.
  33. jonnya
    jonnya Member
    102
    The RS4 IC outlets (upper and lower) require 2.5" ID piping. The offside lower
    charge pipe is also different on the RS4 (longer). See my thread in the classifieds for
    more details :)
  34. Nez
    Nez Member
    598
    Linke please :)
  35. s4marsh
    s4marsh Member
    360
  36. Nez
    Nez Member
    598
  37. Dan Gliballs
    1,568
    Do you have any actual pictures of the IC's and shrouds?
    Cheers,
    Paul.
  38. jonnya
    jonnya Member
    102
    I'll see If I can get some.
    Jon
