RS4 Fuel Valve?
mjr901 Jun 2, 2012
  1. mjr901
    mjr901 Guest
    just wondering whether it's something worth doing for stage 2+? does it make a big difference? I've got everything I need for this stage but I've known people to run these uprated fuel valves aswell.
    Do people run others like R8 ones etc? or do I just stick to the original or indeed use the RS4 valve?
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,451
    589
    100% do it. Valve is £40 from Audi and takes an hour to fit.
    Recommended to me by Revo
  3. mjr901
    mjr901 Guest
    is it just the RS4 one thats used? :)
  4. loudchris53
    loudchris53 Member
    402
    Does this make the car use more fuel?
    Chris
  5. mjr901
    mjr901 Guest
    I cant see it using less tbh so if it aids power i should think, yep, more fuel. but is it worth it.... guess ill just do it anyway!
    grainqey likes this.
  6. loudchris53
    loudchris53 Member
    402
    lol, i suppose! bet it makes a big performance difference though :)
    Chris
  7. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,019
    551
    it holds fuel pressure up, a worth upgrade for that money.
    i'm doing mine as soon as i get time..
  8. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Definately do it. Doesn't make a massive difference but gets rid of the known power dip at 5k rpm.
  9. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Has anyone got a guide to fit this? Looks like a right ***** of a job?
  10. mjr901
    mjr901 Guest
    Just done some more research on this and 99% of people say its an **** of a job. best to let the garage do it for an hours labour.
    backdraft have done quite a few apparently.
  11. mjr901
    mjr901 Guest
    the part itself looks well easy just to screw in.
    i think it's access where people struggle.
    people have to bend spanners etc to do it, some even take off the manifold!
  12. nil538
    nil538 Active Member
    499
    66
    Has anyone got a pic of a rs4 valve next to a standard s3 one ?
  13. JamesS4cab
    1,191
    94
    You won't be able to see the difference from memory. It's just the size of the nozzle on the inside. Bank on an hours labour to fit for someone that knows what they are doing.
  14. s3ollie
    s3ollie Member
    762
    they look identical its the cracking pressure thats different i think its something like 130 bar for standard and 136 bar for the RS4 one.
    I bent some spanners to save taking the manifold off
  15. mjr901
    mjr901 Guest
    would a long socket get to it if you put the 90 degree angle piece you get in these halfords advanced sets?
  16. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
    Hi guys a bent spanner is the best way in ,ohh err misses..this is how statllers done mine..:)
  17. Kelza
    3,078
    605
    Next will be....- HPFPupgrade Stage 2 kit (155bar hpfp + 155bar return valve). 10 times better than APR HPFP
  18. mjr901
    mjr901 Guest
    tell me more......:) linky?
  19. Silky-S3
    1,407
    343
    You wanna lend them out mate? :)
  20. Kelza
    3,078
    605
    Hi silky you not near statllers ask craig for a spare one..lol
    VAGOC.co.uk | VAGOC.co.uk link to stage 2 Hpfp
    S3 dan was using a revision autotech stage 2 Hpfp...:)
  21. downtothebone
    downtothebone Active Member Team Scuba Audi A3 Audi Cabriolet Owner Group S-line owners group
    622
    106
    43
    Is this more for an uprated S3 or will a remapped 2.0 TFSI benefit?
  22. S3Alex
    10,772
    4,791
    Quite likely that until you get to 360ish bhp that it will make little difference but the best way is to log fuel rail pressures and see if there are any significant dips which would make the RS4 regulator worthwhile.
  23. Ben2487
    Ben2487 Active Member
    249
    111
    43
    I called APR to see if I require a rs4 valve for stage 2+ and they said it's not a requirement so I asked would there be any advantage of fitting one and he couldn't really give me answer so I can't understand if it not a requirement the map must run on standard fuel pressure my only concern would there be any points along the map where it would run lean as it couldn't cope with the fuel required. Is it worth doing to be on the safe side? And if I need to take the manifold off to reach it I may vary well do the rfd while I'm there before it goes into mapped
  24. MICHAEL PARKER
    MICHAEL PARKER S3 Sportback
    850
    431
    Aks fitted mine for me .
  25. prt57
    prt57 Well-Known Member
    837
    255
    I am running APR stage 2+ and I asked the same question. This is the reply from Al Brown of Awesome.
    It isn’t required as such, and won’t give any additional power, however one of the reasons we recommend it is because it allows a bit more headroom on the low pressure side of the fuelling system, which means there’s extra there if it needs it. Almost as a safeguard.
    So I had Awesome fit it to my car and they quoted one hours labour. Fit and forget in my view.
    R-Tech recommend it but their maps seem to produce higher torque figures than APR.
    It is not a job for the novice mechanic. I have done spannering for many years now but was worried about getting everything tight enough, especially with the fuel under high pressure. Special crows foot spanners needed if you do it with the manifold still in place.
    Ben2487 and nluk100 like this.
  26. Ben2487
    249
    111
    43
    Exactly what I wanted to know thank you
