RS4 Engine start button on S3
klik Apr 23, 2008
  1. marriedblonde
    marriedblonde Active Member
    4,371
    But you still need the key to be able to operate the car. someone above said they would like the idea of not needing it.
    J.
  2. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I think you should re-read my post.
  3. JohnS3
    JohnS3 Active Member
    3,032
    Here you go... http://stores.ebay.co.uk/CarGravo
    I've got his garage door switch, very nicely made, totally OEM.
    [​IMG] [​IMG]
  4. marriedblonde
    4,371
    Why?
  5. Staz
    6,206
    67
    Nevermind
  6. phantom
    phantom On Boost
    1,750
    Some of the new Renault sports ( not sure about other brands ) have a keyless entry ( a piece of plastic roughly the size of a credit card but thicker ) it senses the card on you and you can open the door, BUT you still need to insert the car to be able to start the car!
    Now imagine if we could go one step further so you get literally a credit card that goes in your wallet , that senses you when you approach the car and starts when you press the start button!!!! all with your credit card key still in your wallet firmly in your pocket!
    That will be decent!:yes:
    p
  7. boggysv
    boggysv Member
    573
    Sounds like the Keyless Go cards in mercs a few years ago. Heard they discontinued it and used fobs instead?
  8. Staz
    6,206
    67
    It's certainly possible!!
  9. marriedblonde
    4,371
    Never mind? Is it because I was replying to this post about not needing a key at all:
    And then you replied saying that you wouldn't need to use a key apart from disengaging the steering lock? (I'm assuming thats what you meant by your post) Which implies you do need to use a key to start the car. When synthdood is talking about the key less entry systems available on the A5
    J.
  10. marriedblonde
    4,371
    Merc, BM and Audi offer it, it's an option on the A5. Approach the car and it unlocks, hop in and press the starter. No need to put a key in the ignition.
    J.
  11. phantom
    phantom On Boost
    1,750
    Thats where it's at!:thumbsup:
    p
  12. Amchlolor
    Amchlolor Active Member
    5,604
    I'd gladly swap the 'start' button for a conventional key, in my car.
    I still can't get used to it, and I'm left handed!
  13. L60N
    L60N Guest
    Cheers John!!
    Just had a peep on ebay and he doesnt have much on at the mo.
    Though I did note one of his items desciption says "Der absolute Hingucker!" I laughed as my mind translated it as "The Dogs bolocks" rofl.
    *Correction, he has **** loads, just click on the 8P button chaps!!
    JohnS3 = Legend :arco:
    Also the seller has put a neat install guid on uchoobe:
    [ytv]w8pG__GMzAU[/ytv]
  14. Staz
    6,206
    67
    Yes I knew you still need a key, you basically repeated my post. But it's not the steering lock I was refering to but the immobliser.
    But anyway.
  15. phantom
    phantom On Boost
    1,750
    Does this fella make them to order?
    I wouldn't mind a Haldex one for when or if i get the GenII controller!
    I'd just want 3 red LED's on it to show which 4WD mode i was in, maybe Haldex written on it too!
    The switch that comes with the kit is like the wing mirror switch i don't want that hanging off my dash!
    p
  16. S3 Big Andy
    S3 Big Andy Stealth Beast Baby Yay
    725
    I want a glowing nob! how do I get one?? ;)
  17. Staz
    6,206
    67
    Rub it.
  18. JohnS3
    3,032
    He does make custom covers for switches, however they rely on the audi switches behind them. I use the tyre pressure switch for my garage door opener, which is press to make and release to break. You'd have to check what type of switch is required for your genII module.
  19. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    9
    Just checked ETKA and the "compartment with cigarette lighter" 8E0863284E5PR slots directly into the hole where your existing cigarette lighter is. The start button then fits into the remaining gap.
    I'm seriously considering this, if only to allow me to hide the controller for my Nokia 610 behind the panel. The start button would make a nice feature, even if it wasn't used.
  20. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I want a red ring around my knob.:sm4:
  21. JohnS3
    3,032
    Be careful what you wish for... :scared2:
  22. N8
    17,163
    718
    The megane did this when it came out in 2002. And NO the key doesn't have to be in the slot as my cousin had one then and has a 197 now.
  23. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  24. N8
    17,163
    718
    :sadlike: got it wrong then. Whats the R26 like compared to your S3? Does it have better handling due to the lsd.
  25. mitch78
    2,350
    :thumbsup:
  26. MarcQuinlivan
    2,539
    9
    Sent my dealer a mail last night to get a price for the parts:
    8E0 905 217 - (Push button for starter system) £54.99
    8E0 863 284E 5PR - (compartment for centre console with cigarette lighter and switch mounting). £45.83
    I've asked him to check if there is a power connector available for the bottom of the start button.
  27. Kontraband
    Kontraband Active Member
    2,008
    the key didnt need to be in my 05 BMW to drive it either... it needed to be in it to verity the start, but you could stop, take it out and then press the start button again and then drive off....
    Dunno why you'd want to do this, or if its a general bug... but that was the way it was. Also with it being on the left, it was a pain, but then I got used to it, and everytime I got in a different car Id have the keys in my left hand... of course now I need some more brain training to get the key back to my right side!! :rtfm:
  28. MarcQuinlivan
    2,539
    9
    Just checked with an Irish dealer and the parts are
    start button - €83
    console - €110
    The total price of the parts in the UK is €126, so I'm going to order them from my dealer in Belfast.
  29. Kontraband
    2,008
    eh?? Have I got up late? Isnt it more expensive to order from Belfast???
  30. MarcQuinlivan
    2,539
    9
    nope - it is costing me 126 euros to buy them in Belfast, or 193 euros down here.
  31. Kontraband
    2,008
    check, Belfast = UK, Irish = S.Ireland.
  32. Kontraband
    2,008
    HAHAHAH this is confusing...
  33. marriedblonde
    4,371
    Ok I've finally caught up as well...
  34. Staz
    6,206
    67
    How do you plan to wire it in Kontraband?
  35. Kontraband
    2,008
    staz, Im not... MarkQ is.
  36. Staz
    6,206
    67
    Oh yes you're right. Now I'm getting confused for no reason. This thread is jinxed.
    So.....MarkQ......same question.
    :jester:
  37. Kontraband
    2,008
  38. MarcQuinlivan
    2,539
    9
    Who is this MarkQ chap?
  39. MarcQuinlivan
    2,539
    9
    The main reason for buying the bits is so I can hide my Nokia 610 controller. I'm sure I can rig power up to the button for the illumination easily enough.
    The dealer wasn't sure what connectors were needed, and I couldn't work it out from ETKA. When I have the button I'll be able to see what connectors it needs and then attempt to hook it into the ignition system (maybe!).
    If I can't get it to work I can always try to bluff my passengers by turning the key at the same time as pressing the button!
  40. marriedblonde
    4,371
    you could always save your fuel and bluff them by making engine noises...
