RS4 Brakes
S4twiggy Mar 27, 2010
  1. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    picking up my RS4 brake setup tomorrow so my brakes should be up for sale soon. not yet though as not fitting till i refurb them and after GTI spring fest. jus letting you lads know if you want an upgrade for your B5 A4's then i have the brakes for you!
  2. aragorn
    18,032
    722
    Mind they wont fit normal B5's, without using S4 uprights!
  3. S4twiggy
    1,815
    9
    fair enough. in the B6 section they go then. cheers
  4. S4twiggy
    1,815
    9
    picked up these this morning, £200.
    i will be refurbing the pistons with a good clean and new seals and putting braided lines.
    all i need is pads now so any suggestions? Mintex, Pagid or ferrodo. not sure on the red stuff EBC
  5. G8ANT
    G8ANT New Member
    Bargain :thumbsup:
  6. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Yeah right bargain! I would go for Ferodo DS-2500's. Awesome pads. But as usual, because of the performance they are pricey (but IMO worth it!).
  7. Nez
    Nez Member
    598
    You love the power of these brakes man once you fit them :) I get my rs4 brakes front and rear for £350 but they were fully refurb :)
  8. bad-vw-boy
    bad-vw-boy Member
    72
    Is the rs4 brake bigger than the s4 brake and will they fit under the Avius 17"
  9. Nez
    Nez Member
    598
    The calipers are not big but the discs are bigger then S4 360mm and you need 18" rims it won't fit under 17"
  10. S4twiggy
    1,815
    9
    cheers mukka, ill put them to good use. now go get them springs and get that RS4 on the road dude:icon_thumright:
  11. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,769
    31
    I've got some part worn DS2500 rear RS4 pads if you want them. Still got quite a bit of meat on them and they are in good condition.
    I've 'downgraded' to B6 S4 rears because of the ludicrous price of replacement RS4 rear discs (£450!).
  12. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    i might take those off you if he doesn't want them.
    for B5 rear calipers are they?
  13. S4twiggy
    1,815
    9
    take them mate, im only fitting fronts to mine for now.
  14. S4twiggy
    1,815
    9
    got these this morning, going to be fitting on the weekend once i get DOT 5.1 fluid, this setup should give me a substantial upgrade over my standard S4 brakes which i think lack stopping power.
  15. aragorn
    18,032
    722
    Arent you missing the other two hoses for the rear?
  16. Nez
    Nez Member
    598
    He is not fitting the rears only fronts :)
  17. Nez
    Nez Member
    598
    Do you really need to put DOT 5.1? as I only used DOT 4.
  18. Broken Byzan
    13,237
    465
    Nez, DOT 4 will be sufficient don't worry.
    I would say those hoses are axle to caliper for the rear, other wise they are far too long for any of the other applications i can think of
  19. S4twiggy
    1,815
    9
    hoses are not that long. about 12 inches probably, same lenght as the OE RS4 hoses
