RS4 bar fitted, anything else??
Gaz! Oct 6, 2013
  1. Gaz!
    Gaz! Member
    159
    14
    Ive just fitted an RS4 rear anti roll bar, huge difference. It has tightened the car up, but it does still wallow compared to my other cars.
    So, as well as the rear RS4 bar, can the front RS4 bar be retro fitted as well?
    Also what about strut braces? Ive seen, B5, B7 and B8, but no B6 strut braces.
  2. crazy88
    crazy88 Loving the anonymity
    4,939
    437
    As far as I know there is no difference between the different models for the front sway bar.
    There's aftermarket ones that people use though. I'm sure I've read if someone on here who has done it.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,136
    the lower anti roll bar is the same on the a4 and s4 and rs4
    however the s4 and rs4 also have a top mounted anti roll bar .... im not sure if the a4 does or not
    stiffer roll bar will help the car as regards rolling and wallow but will be poorer for traction as the suspension cannot move as much
  4. Gaz!
    Gaz! Member
    159
    14
    I'm surprised the front is the same. So no strut braces that fit?
  5. dualmono21
    1,136
    s4 and rs4 has a top strut brace which fits across where the battery sits
  6. hades-
    9,481
    646
    the top strut on the a4 is built into the front where batt sits as above
  7. DieselJake
    DieselJake Well-Known Member
    2,425
    483
    Springs and dampers should be good to stop said wallow.
  8. worcesternaf
    worcesternaf New Member
    17
    what springs/shocks are people running on their cars? make/drop/prices/dealer?
  9. A4sportMrT
    A4sportMrT Member
    273
    23
    Where did you find the rear RS4 ARB?
  10. DieselJake
    2,425
    483
    Eibach Pro Springs and AP Dampers for me, works well although the 19's make it a fair bit stiffer than most.
    Looks lower in person, just the right drop in my eyes 30mm all round (according to them)
    Dealer's cheapest... I think?
  11. Gaz!
    Gaz! Member
    159
    14
    Audi
  12. A4sportMrT
    A4sportMrT Member
    273
    23
    thank you :)
  13. dualmono21
    1,136
    running koni adjustable shocks and h+r springs with a 20mm drop + the rs4 rear anti roll bar
  14. adamss24
    adamss24 Well-Known Member
    4,578
    402
    Then the only solution is to swap your existing suspension to some quality coil overs or at least upgrade the shocks with some bilstein ones... I have bought a car with koni FSD suspension at some point, in the bin they went and i replaced the shocks and springs with genuine s6 dampers and Eibach springs...much, much better !
  15. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I have an RS4 Rear ARB with Weitec (KW) coilovers.
    Handles really well around corners, however they can be a little harsh under normal driving - but I can live with that!
  16. SmoothAssault
    SmoothAssault Will design for mods
    822
    53
    I've got an RS4 rear ARB and new Tein rear springs to fit in the next couple of weeks. Anyone have some tips on the best way to go about installing both at the same time; what should go first? Or will it not really make any difference?
    I want to avoid putting things back together only to find they need to come off again, if possible. Thanks.
  17. dualmono21
    1,136
    fsd ones are the active ride control
    surprised you couldnt find an adequate setting for them , drove a seat leon with them fitted and they seemed pretty good
    eventually bought the pro sport ones for both the leon and the s4 .... lifetime warranty on both sets
  18. worcesternaf
    17
    Can you do us a piccy staright on from the side mate? would like to see what the drop looks like.
    ive ordered the rs4 rear bar.
  19. dualmono21
    1,136
    worcesternaf likes this.
