RS4 ARB onto 1.9tdi
stuart.garlinge Oct 17, 2011
  1. stuart.garlinge
    stuart.garlinge Member
    64
    Hi, Will the arb from an RS4 fit onto a 1.9tdi avant, are the arb's different from saloon to avant, going to lower the suspension and while i'm at it going to replace the drop links and want to do the rs4 arb mod, i know it's quite a straight forward job but would hate to order parts that don't fit etc. cheers.
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    yes saloon and avant the same and they fit a treat
  3. jbcalvin
    jbcalvin Member
    691
    21
    Did this earlier this year and there is a whole thread on it if you do a search......
    part number are in the relevant sticky.....
  4. white.akita
    white.akita Active Member
    322
    30
    why put a rs4 arb on my 1.9tdi ?
  5. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    why post silly things ^
    you ever thought of improvements
  6. hades-
    9,482
    646
  7. Paul @ Unit 9 Remaps
    2,035
    132
    i dont mean to sound arrogant or anything but Hell' its not hard to figure why, need to get around purchasing one myself, my back end is twitchy as hell
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,501
    3,060
    An uprated rear anti-roll bar won't make the back end of the car less twitchy.
  9. jdp1962
    8,501
    3,060
    The RS4 rear anti-roll bar is thicker than the standard bar (22mm instead of 16mm), so it increases roll stiffness at the back of the car. This in turn reduces understeer, and makes the front of the car more responsive when cornering.
  10. hades-
    9,482
    646
    this is geting good
  11. Paul @ Unit 9 Remaps
    2,035
    132
    a RS4 Anti roll bar along with my AP coilovers will work wonders compared to the standard set up along with new rubber
  12. marktdisport
    marktdisport Active Member
    1,195
    15
    my ARB'S ON my subaru was the best mod id ever purchased but it was the front that altered the car big time took away the 4wd understeer and changed the car dramatically i had 24mm front 22mm rears...... this helps big time when you have a bit of weight in the car's build aswell
    and more to the point Y NOT LOL !!!!!
