rs4 allow wheel enquiry
audia4sline Jul 20, 2009
  1. audia4sline
    audia4sline New Member
    Im looking to buy some audi rs4 replicas does anyone know of a gud place online to get them.
    Iv seen some grey ones at wheelbase which look ok. and thinking of getting the 18s over the 19s because it would look too big on me a4 sline
    can anyone advise me
    cheers
  2. Yellowtrophy
    Yellowtrophy Member
    108
    I have 19" R8 wheels on my car, and they are from Wheelbase. I didn't like the colour, so I've just had them painted. However, Wheelbase are a really good setup, and I would definitely use them again.
    18" is the standard size of wheels on an A4 S-Line, and I think they look a bit small (especially on the cabrio, for some reason). That is why I went for 19" replacements. I had the RS4 style wheels as standard (mine is the S-Line Special Edition Cabrio), and I really do think they look too small.
    However, if you go for 19" wheels, it makes the car look a bit high, so you really need to get some coil-overs (or at least lowering springs) to keep it looking right.
    Depends on how much you want to spend, but to answer your question, I can only recommend Wheelbase for buying alloys.
  3. audia4sline
    thanks for that, its these wheels http://audi.wheel-base.co.uk/proddetail.asp?prod=New-RS4-StyleGM.#
    on the site it has the following info:
    [FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]BOLT PATTERN: 5x100 [/FONT]- 5X112
    [FONT=Verdana, Arial, Helvetica, sans-serif]OFF-SET: 35mm - 45mm[/FONT]
    [/FONT]
    How do i find out which size i need etc
    [/FONT]
  4. mooney3019
    mooney3019 New Member
    21
    I have a 2nd hand set for sale in the classifieds £200 with 3 decent tyres
  5. Yellowtrophy
    Yellowtrophy Member
    108
    Assuming your car is the B7, then you need the 5 x 112 pattern, centre bore is 57.1, and the offset as standard is ET45, but you'll be fine up to ET35. Remember the lower ET number, the further the wheels stick out.
    However, tell the guys at Wheelbase what car you have, and they'll make sure you get the right setting for you new wheels.
