rs4 18" alloys which ones fit? (anyone heard of px wheels, looks really good!)
hank3944 May 8, 2011
  1. hank3944
    hank3944 Member
    146
    Hi I am sure this has been asked a 1000 times but which ones will fit without any full lock rubbing? will I need any spacers? and what offset will in need? Am I right in thinking that these were a optional extra from the factory?
    Any of these any good (part ex your rubbish wheels for new refurb ones....)
    px-wheels | eBay UK
  2. hank3944
    hank3944 Member
    146
    come on guys i know lots of you know the answer to this.....
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    What car will they be going on? Standard brake calipers?
    You need to get the 5x100 ET35 wheels and they should fit on just fine. SuperKarl has some that are ET45 and he needed spacers so try to get ET35 if you dont want to shell out more money.
    I was keeping my eye on that PX wheels but they will only replace like for like wheels wont they? Good if you have a set you want to get refurbed.
  4. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    On an a3 or s3 mate? the offsets are a bit different.
    Standard s3 Avus Wheels are 17x7.5 et32 and 5x100.
    Generally 10mm spacers up front and 15mm spacers at the back are used by s3 owners but I understand theres space for 5mm extra on each.
    Do you have a link to the wheels you want?
  5. Dane
    4,086
    182
  6. Lingo89
    Lingo89 Member
    114
    Sorry if I've misinterpreted this thread in advance, but are you guys saying that if you fit 18" alloys on a standard A3 without adding spacers the front wheels will rub at full lock?
    Thanks.
  7. Westy
    17,443
    1,103
    No we're only talking about RS4 wheels here. There are RS4 wheels which are ET45 which need spacers, RSTT wheels which are ET35 which need spacers or you can get reps of these wheels which are standard ET32 which wont need spacers.
    The problem isn't with rubbing the arches but with the inside of the wheel catching the brake caliper.
    Lingo89 likes this.
  8. hank3944
    hank3944 Member
    146
    I was thinking these... Is there a certain tyre you have to have fitted?
    also this might be a bit of a numpty question but does changing the wheel size affect the speedo reading?
  9. hank3944
    hank3944 Member
    146
    Sorry, to be fitted to a 2001 s3, standard calipers.
  10. Westy
    17,443
    1,103
    Normally you'd get a tyre that makes the rolling radius of the wheel the same as when you have the 17" wheels on. The 18" S4 wheels I just bought have 235/40 tyres on them but the diameter of the wheel and tyre is the same as my standard 17" wheels and tyres.
    Do you know what ET (offset) the wheels you're looking at are?
  11. hank3944
    hank3944 Member
    146
    So if my normal wheels are 17", 5 stud Avus et32 with 225/45/r17's what would be the equivilent (no rubbing on full lock, speedo still reading correctly, calipers clear, filling the wheel arches) 18" straight swap?
    18" et32 with ***/**/*18's ? with 5 x 100?
    Thanks...
  12. hank3944
    hank3944 Member
    146
    So would et33 fit?
  13. <tuffty/>
    20,904
    3,713
    RSTT OEM wheels are 18x8 ET33 so yes...
  14. superkarl
    superkarl MAN OF STEEL
    9,406
    2,379
    tire wise you need to be looking at 225/40R18 to keep speedo accurate, or within the tolerance
    use this..
    Tire Size Calculator - tire & wheel plus sizing
    i foound my speedo is now more accurate with my new size.
    places reccommend no more than +/-2.5% some people say it can be more. but little difference the better
