RS3 Wheels On S3
CatnipRS3 Jul 4, 2013
  1. CatnipRS3
    CatnipRS3 Active Member
    208
    110
    43
    Hi
    Can someone confirm if RS3 19 x 8J rims fit on a S3 (8P) and what size tyres are best?
    Photos if poss!
    Cheers guys :yes:
  2. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    Offset should be fine for RS3 onto an S3, not sure of the offset but they'll probably sit a touch further out than standard (which is what most people are after anyway). On an 8" you should go for 225/35 R19s.
  3. L1ARR
    L1ARR Active Member
    424
    43
    Warren fitted a set straight from a RS3 last year, have a look out for his build thread.
  4. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Isn't the offset of standard RS3 wheels 50? If so, they fit fine, may want some spacers to fill the arches a bit more though.
  5. N8
    17,163
    718
    Yes they will fit. 225/35 or 215/35
  6. CatnipRS3
    208
    110
    43
    Great...thanks guys!
  7. sliced
    sliced Drive safe, stay alive.
    1,524
    327
    they look a bit odd on a 3dr, but on a 5dr :anbet:
  8. JamesS4cab
    JamesS4cab Well-Known Member
    1,188
    94
    I don't think they look too bad on a 3 door.........
    But then maybe i'm biased!!
    Mine are 8.5J et43 with 235/35/19 and they rub a bit given that i am lowered 25mm on H&R's. Which is quite annoying..........
    dzTT and Dean_T like this.
  9. S.
    S. Well-Known Member Team Ibis TFSI Owners Group quattro Audi S3 Manual
    1,937
    499
    on front or back?
    for front you can get adjustable ball joints to adjust camber, and at the back you can adjust it without extra parts.
  10. S3Alex
    10,362
    4,404
    At the back,it's simple enough to get 3degrees or more negative,and as you say,at the front,if you want a little bit of neg,you can use the TTRS TCAs,and for more,you need adjustable topmounts and serious cost.
  11. N8
    17,163
    718
    That's it!
  12. whitex8p
    whitex8p Member
    108
    They look the awesome mate, when i have the cash will consider some for sure
    JamesS4cab likes this.
  13. JamesS4cab
    1,188
    94
    They rubbed front and back.
    Dont anymore cos I took em off as they annoyed me!
    Fronts went back on this morning with 225/35s to fit over the new brakes.
    Need some 225's for the rear now.
