RS3 detailed
tee-bee May 2, 2013
  1. tee-bee
    tee-bee Member
    80
    I'm having my RS3 detailed & protected:
    15 stage wash using 2 bucket method
    Wheel arches cleaned
    Wheels cleaned using alloy wheel cleaner
    Clay bar used to remove bonded contaminates from paintwork (inc door shuts)
    Vehicle re-washed and dried
    Paint depth readings taken
    1 stage paint correction completed
    Vehicle wiped down with a isopropal alcohol (panel wipe) to make sure surfaces are clean
    Pre-selected wax/sealant is applied (GTECHNIQ)
    Door shuts waxed for added protection
    Interior cleaned and vacuumed
    Interior plastics dressed to finish of your choice
    Door seals and rubbers cleaned and protected
    Interior glass cleaned
    Exterior glass cleaned
    Tyres cleaned and dressed with a long lasting tyre gel
    Exterior plastics dressed
    Paintwork checked
    Final inspection to make sure your car meets our high standards
    Approx 15-20hrs (3 day booking)
    What are your thoughts?
  2. quattro81
    quattro81 All the gear.. No idea
    970
    90
    I think three days is a bit slow... But the correction will be what takes the time.. One stage should be quick really unless your paint is completely wrecked? I just had mine done with pretty close to what you listed, except with a 3 stage mop, so my paint is looking like glass! And also had some premium swissvax carnauba put on too.. It took a day (8hours), but my paint was really good already
  3. P_G
    P_G Active Member
    381
    91
    3 days is a bit long. I am also having G-Techniq C1 applied to my RS3 in a couple of weeks and am being quoted a day and a half for full paint correction, C1 application (overnight cure) and final inspection by a G-Techniq approved detailer. Admitedly I'm not asking for the interior or wheels to be done but those in themselves are not a 1.5 day job.
  4. tee-bee
    tee-bee Member
    80
    Can you all share the URL of the detailer? also pricing..? PM if need be..
  5. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,252
    10,228
    Have you had a quote from N8. He did a fantastic job on Robbiemacs car. :) x
    Kowalski Details
    robbiemac likes this.
  6. tee-bee
    tee-bee Member
    80
    Am based in Berkshire.. so not sure if the detailer is close by...
  7. P_G
    P_G Active Member
    381
    91
    DDB Valeting in Newcastle is the company doing mine. I would thoroughly recommend Cambridge Autogleam albeit not that local to you, Nathan does outstanding work on some very top end cars but treats each one to the same high standard and not a million miles away from you.
  8. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
    monkeyboy_marcus likes this.
  9. PigPen
    PigPen Member
    236
    15
    Check out Shine On Detailing - just down the road from you. Did paint correction and detail in two days. Finishes with Swissvax as above.
  10. Kelza
    3,078
    605
    Love my sv shield ;)
  11. Moschops
    Moschops Active Member
    298
    147
    43
  12. dbm
    dbm Active Member
    640
    186
    43
  13. N8
    17,163
    718
    We can deal with all your detailing needs, check the writeups to follow soon. T5/RS3 & a full detail on a F458.
  14. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    886
  15. dbm
    dbm Active Member
    640
    186
    43
    I guess you get what you pay for. :)
  16. JonnyG
    JonnyG Active Member
    227
    67
    1. How much is that costing is my first thought !? 2. I would'nt wax the door shut area ... the doors may start to creak and squeak !! Just use a sealant and Autoglym Vinyl & Rubber Care on the rubber and felt seals - that has cured my creaky drivers door seals. 3. Ask for Gtechniq C1 followed by EXOv2 - this will give you better swirl resistance (C1) and a fantastic slick and glossy finish (EXOv2). 4. Gtechniq stuff needs to cure indoors for 12 hours so 3 days is reasonable as long as the cost doesn't include curing time. 5. For that level of detail get them to seal all your glass with Gtechniq G1 ... just a clean isn't good enough !!!! 6. For a three day detail your alloys should be taken off and cleaned, clayed, polished, clayed and sealed with Gtechniq C1 and EXO as well. Hee hee .. be tough with them and get the ultimate detail :sm4:
  17. JonnyG
    227
    67
    And they forgot your exhaust ... you want that chrome cleaned and polished with Gtechniq M1 :arco:
  18. Kelza
    3,078
    605
    Some detailing can cost over 1k guys no joke ...
  19. monkeyboy_marcus
    monkeyboy_marcus Active Member
    353
    137
    43
    Keen to do this too, once brake fix is out, windscreen is fixed and (possibly) paint shield is applied. Any recommendations for SE/Kent/Surrey? Also, if your beast lives on the driveway and you do a lot of miles, how long does the loveliness last before fading? Seems like the few times I've cleaned the car she's got grubby within a couple of days, although I appreciate it's a different level...
  20. Kelza
    3,078
    605
    Hi marcus check out the dw list to see your nearest detailer as theres a few in surrey ;)
  21. P_G
    P_G Active Member
    381
    91
    True but the difference is whether you can tell. The detailers who use waxes at £2k per 500ml tub do a great job however I suspect 90+% of the population wouldn't be able to tell the difference between that wax and Collinite for example.
  22. finchy256
    finchy256 Member
    37
    N8 likes this.
  23. Brodster
    3,548
    886
    Yes your car is going to get dirty but after the hard work of removing all contaminents and blemishes and making it glass like the majority of all the dirt will be easy to remove with a quick wash as all the hard work has been done. The duration of the sealant/wax etc will depend on what it is. 22PLE glass coat is said to give 12-18 months protection whilst there are some waxes that give 3,6 months. All depends on what you want really.
  24. dbm
    dbm Active Member
    640
    186
    43
    If you are thinking of getting Paintshield, here is a pic of my car after it was done:
    It has the full front and half the wings and bonnet done (up the centre line of the wheel arches). This is the second car I've had them do for me and I find it worth the cost, personally.
    monkeyboy_marcus and Vito like this.
  25. wickedstef
    wickedstef Active Member
    138
    43
    dbm, can the same company do a paint correction/thorough wash prior to application? The thing is, if I get the car a paint correction and a "detail", i don't want to drive it even 50 yards outside before it gets the 3M shield...
  26. P_G
    P_G Active Member
    381
    91
    Most of the Ventureshield installers can do paint correction as part of the package for you or if not, will know a detailer who would come in and do that for you on their premises. Paintshield also said to me when I enquired they would do paint correction if ask for and TBH it is worth doing even if you only have slight swirling because as much as it is a film, it does not hide imperfections in the paint.
  27. dbm
    dbm Active Member
    640
    186
    43
    I never asked if they could do that, but I am sure they can. They tend to work with top-end motors so I'm sure they get asked for it by the real car connoisseurs.
  28. wickedstef
    138
    43
    Cheers guy. I think I may well do this before our next meet. This car gets stones chips all over the bonnet (and I'm not mentioning the windscreen) and seems very fragile.
  29. Kelza
    3,078
    605
    Hi wickedstef try wolfs hardbody a few coats should help...;)
  30. wickedstef
    138
    43
    Thank you for the advice RS3-KEL.
    Who wants to offer the full package (paint correction + detail + sealant + ventureshield) around Berkshire for a fair price? I think I'd like to cover the front bumper/headlamps, full bonnet, arches and wing mirrors covers...
    Just realised, sorry for the thread hijack :blush:. Maybe tee-bee and other southerners (Bilen, PigPen if not too far), might be tempted by a group buy?
    45bvtc likes this.
  31. Kelza
    3,078
    605
    I know a few detailers ,but there more up north ;)
  32. wickedstef
    138
    43
    Yeah I guessed :)
  33. Kelza
    3,078
    605
    Check out the dw list on post 8 ;)
  34. wickedstef
    138
    43
    Thank you! :)
    45bvtc and Kelza like this.
  35. dbm
    dbm Active Member
    640
    186
    43
    My TTS did over 80k miles and the was still perfect.
  36. Kelza
    3,078
    605
    Hi dbm ,paintshield film is not going to be cheap ,i did email elite but they never got back to me ...
  37. dbm
    dbm Active Member
    640
    186
    43
    I think it was around £800 for my coverage, might have been a bit more. I do high mileage so it's worth it to me.
  38. monkeyboy_marcus
    353
    137
    43
    I asked this question today and they have a detailer who can work from their premises. Cost for what dbm has had done (I think) is about a grand, third front end only is about £500 and full body is £3.5k.
  39. monkeyboy_marcus
    353
    137
    43
    Standard kit: Bumper, part bonnet (wrapped edges), part wings (inner edges wrapped) wing mirrors: £525.00 + vat
    Full Front kit: Bumper, full bonnet (wrapped edges), full wings (inner edges wrapped), wing mirrors: £1200.00 + vat
    Complete kit: Every external painted panel on the car protected: £3400.00 + vat (4 Door version)
  40. monkeyboy_marcus
    353
    137
    43
    I'd be interested in a group buy for paintshield and detailing... They're based in peterborough I think.
