RS3 8v countdown thread :)
number3 Jul 19, 2013
  1. Psyman79
    Psyman79 Sarcasm is hard on a forum ;) Team Vegas Yellow Audi S3
    880
    700
    93
    3 door has a longer wheel base based on total length of vehicle. This would surely mean it would handle better than th SB.
    I could well be easily confused though :)
    Si.
    PilotAudi likes this.
  2. PilotAudi
    PilotAudi New Member
    2,352
    479
    Yes Si... you are easily confused! Try a google around on the subject!
  3. Psyman79
    880
    700
    93
    Confused as to why i'm confused though. SB is 73mm longer but the wheelbase is only 35mm longer, would that not mean that the 3 door wheels are closer to the corners of the car thus improving handling. :think:
  4. S3Alex
    10,581
    4,649
    I wouldn't hold my breath on that one.
    It would be nice,but Audi seem pretty into the 5 door thing right now,and it certainly put me off the RS3 8P.
  5. R90 STL
    R90 STL Well-Known Member
    615
    299
    never realy been into the SB but the 8v is a huge improvement on the 8p
  6. S3Alex
    10,581
    4,649
    That in itself is good news,as the 8P did need a lot doing to it to make it behave and perform as you might have expected.
    It was a classic case of a great engine in need of more power and a better chassis.
  7. PilotAudi
    2,352
    479
    A vehicle's dynamics is a function of:
    -wheelbase
    -CG height
    -mass
    -mass distribution
    -track
    The effect of a longer wheelbase on longitudinal acceleration is analogous to having a wider track during lateral acceleration. All inertial forces act through a vehicle’s centre of gravity, so having a larger distance between the axles or inner and outer wheels has the same effect as lowering the CG: reduced load transfer. Reducing load transfer will result in more balanced tractive forces at each tyre. This is a good thing because when a tyre is overloaded, it will slip too much and eventually lose grip and skid. And if underloaded, the normal force may go to zero and the tyre does nothing.
    However, track width and wheelbase length are a compromise between dynamics (geometry and inertia) and packaging. These parameters are fundamental to all further design areas such as suspension geometry, wheel rates, damping rates, traction control, brake system, gearing, powerband etc… Therefore these parameters are established very early on in the development process.
  8. lee_fr200
    lee_fr200 Active Member
    820
    189
    43
    Is it just met hat thinks the sportbacks are prettier than the 3dr even on the older 8p
  9. Psyman79
    880
    700
    93
    Pilot,
    Not really sure how that helps the point you are making. 3 door weighs less and has a larger wheelbase based on the overall dimensions of the vehicle. A larger portion of the SB is outwith the wheelbase so therefore acts against the CoG.
    I think i'll stop now though as my brain hurts :)
    Si.
  10. SilureMark
    SilureMark Active Member
    484
    221
    43
    I'm with you on that one, well sort of. Previous s3 I would say the 3 door every time looks wise, but there's something about the latest sportback that just makes it that bit better looking than the 3 door IMO anyway, but don't get me wrong, the 3 door still looks pretty good.
  11. lee_fr200
    820
    189
    43
    Oh yeah the 3dr is pretty good but the sb is just so much nicer, but then I prefer the rs4 estates and rs6 estates to their saloon counterparts, maybe it's the whole thought of been able to carry 5 up and have a boot full and still be able to whoop most cars arses
  12. pat15312
    pat15312 Well-Known Member
    530
    252
    The 3-door looks like a hatchback, the sportback looks like an estate car. If you had to have a practical 5-door car for family, work or other practicality reasons, surely the A4/S4/RS4 Avant would fulfil you needs better? Granted it's a more expensive vehicle which I can only assume is the reason why the A3/S3 sportback is so popular.
  13. Itguy
    Itguy Well-Known Member
    1,130
    449
    An s4 is much more cost in all respects than an s3 SB.
    Car purchase, mpg, insurance, tyres etc.
    I also have to park in city car parks a bit with my job and I for one will appreciate the slightly smaller dimensions of the s3 vs s4.
    Plus, with a new s4 now I'd always be thinking I haven't got the big daddy rs4, making me depressed every time id drive it!
  14. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    I'll try and dig it out ........ And I'm sure someone on here posted a 4.2 seconds 0-60 time with launch ! New s3 8v that is.
    Sean
  15. s33nyboy12
    1,484
    195
    0-60 - 4.29 secs / 60 feet - 1.84 secs / 330 feet - 5.16 / Peak horsepower 277 / Data quality registered as best, Done in the WET!
    Share
  16. PilotAudi
    2,352
    479
    These aren't official Audi figures... I am sure someone has got an RS3 quicker!!
  17. pat15312
    530
    252
    See below official figures for:
    8P RS3 Sportback
    8V S3 Sportback
    So yeh, official figures show the old RS3 is 0.2secs faster to 60mph that the new S3, even if it is 205Kg heavier!
  18. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,480
    1,124
    Barely worth mentioning then!
  19. keyser
    keyser Active Member Audi S3
    118
    57
    8P 5dr was better looking IMO (I had one).
    8V 3dr and 5dr pretty evenly matched, so comes down to what you need (gone for 3dr this time).
  20. royalsteve68
    royalsteve68 Active Member
    984
    224
    43
    Agreed. Also it cant be too much more than the A45 as that's its direct competition
  21. royalsteve68
    984
    224
    43
    it isn't, I looked at one and the rs4 - rs4 had a big dealer contribution of £7K if done via finance but it was the eyewatering cost of the options like ceramic brakes that put me off, plus the sheer size of it.
    The s4 will cost more as it will depreciate like a sieve whereas the s3 sportback is the 3rd best car for lowest depreciation - only beaten by the Range Rover Sport and Porsche Boxter or Cayman
  22. lee_fr200
    820
    189
    43
    if audi are smart they will price it exactly the sameas the a45 but give it more standard options
  23. Cumbrian_bob
    Cumbrian_bob Member
    227
    104
    Audi are smarter than that, they will sell it as 40-45 and hurt you even more with the options. Thats what they do, and they do it so well there is a 3 month wait for the S3. It will all be hypothetical for me if you can stick a roof box on a TTRS 2016 version, lots of if buts and maybees
  24. lee_fr200
    820
    189
    43
    I'm just gonna wait and see what happens I'm saving up at the mo for a deposit so when I'm at the point of ordering I will decide then what I'm having if the s3 and rs3 can't have a tow bar fitted at all I will be going for the 184q instead
  25. Derbz
    Derbz Member
    79
    29
    Was chatting to my mate who works at Audi last night he said its looking like the RS3 could be delayed untill 2015 now!
    Anyone else heard similar??
  26. cemerson
    4,480
    1,124
    How can something that never had a release date in the first place be delayed?
  27. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,703
    1,519
    RS models always take a while, in some cases coming out just before the model is discontinued, I hope that's not the case here.
  28. Derbz
    Derbz Member
    79
    29
    I dont think a release date has ever been mentioned? but It was meant to be revealed in march and its looking like it could be next year now.
  29. Derbz
    Derbz Member
    79
    29
    I cant see Audi doing the same as the last RS3 the demand is just to high for them to wait around, look how quick the new golf R has come out after the GTI.
    I really hope it is this year but only time will tell.
  30. R32 mad
    R32 mad New Member
    15
    9
