Rotation of Tires
Nitro Jul 9, 2010
  1. Nitro
    Nitro Member
    183
    How often should you rotate your tires on a A4 quattro, put four new pirelli's on at the MOT a few thousand miles ago and how many miles should I cover before rotating them.
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,005
    765
    I would not bother, I always leave the tires with most meat on the rear. I would only swap them around when the fronts need changing.
  3. jcb
    jcb Active Member
    4,132
    13
    never bothered.
    if the are wearing at such an uneven rate to be noticeable then you either
    a) have an alignment/tyre pressue issue
    or
    b) just aren't driving it hard enough! : )
  4. aragorn
    18,608
    871
    I'm with B5NUT.
    Ye you can rotate them round etc, but personally, i find that if you just leave them be, the fronts wear out first, then you move the rears forward and fit the new tyres to the back. This means you shouldnt have to shell out for 4 tyres all at once again, and by having the more grippy tyres on the rear, keeps the handling nicely balanced.
