Roof problem on a B6 cabriolet
robbie21mcn
Hi guys my car has developed a problem with the roof. it will go down no problem at all but when coming up to close stops at the very end and does not lock into place. if i use the manual tool it still displays the roof icon on my display as a solid light. my car always had the roof icon flash ten times on start up but worked perfectly. it does exactly the same as this youtube video i spotted. any advice would be really grateful thanks rob.
How to fix my roof on Audi A4 convertible - YouTube
1st off is a manual reset
you will find how to in the hand book
2nd get it scanned it could be a micro switch or a sensor
and theres quite a few
Where is the sensor located that tells the module that the roof is in position to lock. This would seem to be at the root of all my problems since when the roof is down all is well but when it gets into position on the pillars there is no signal to the front motor to pull the latches into place in order to finalize the close procedure. I took the motor out and it goes back and forward so cannot be this. :-(
its in the lock
thats why i said do the manual reset as in handbook theres a good chance it will clear the error
or scam it you will be wasteing cash and time just swapping parts
iv done quite a few and its diffrent every time
when you say it is in the lock do you mean inside the soft top or inside the pillar at the top of the windscreen? i locked the roof into place using the tool but the car is still under the impression the roof is not secure even though mechanically it is. to me it is as if just before you lock the roof into position you had pressed the switch back to stop and then tried to drive. i get a warning saying soft top not secure. no errors or problems with the soft top down as the lock at the rear is working fine. is there any photos? i did take out the motor at the top of the soft top and it only has two micro switches near the motor to tell it to stop in either direction. i tested the motor and it was going backwards and forwards with a 9v battery.
like i said DO full manual reset look in the handbook not just lock it at the front doing this sorts it 90% of the time
theres loads of sensors it can be that why i say get it scanned and it will point to the fault
last time i had 1 that wouldnt lock on close it was a sensor on the drivers side rear in the hood
i didn't do a full reset as i thought because it had done most of the operation itself up until the last procedure of locking. i will give the full reset a bash tomorrow and get back to you. thanks for the help in the meantime.
no probs but by it doing most and you just locking thats wont work
still not functioning guys. how does the roof know it is to lock when it gets to the very last stage? is there a sensor that tells it is in poisition? even when manually locked down it flashes above 40mph telling me the roof is not secure so to me it appears as if the car thinks the roof is still unlocked at the front of the windscreen. :-(
if the manual reset didnt work
you really need it scanning see what code you get and take it from there
guessing is gona cost you loads
As Bez has said, have you tried manually opening fully, locking cover with roof key, closing, locking with roof key, re-opening etc, a full cycle if i remember from reading other problems people have had. I think there are quite a few similar past threads desribing a full reset. This does usually clear problems. If you have tried that fully, then a scan is the next course of action to be able to diagnose further. Good luck.
manual reset; open and close full cycle on a flat level surface.
