Roof leaking any suggestions ??
AdamCarey Nov 24, 2006
  1. AdamCarey
    AdamCarey New Member
    9
    The roof on my 93 cab is letting in water between the windscreen surround and the roof, if I look carefully where they meet in daylight I can see there is a small gap but obviously enough to let in water, its worse when its been raining and then I take it for a drive as water drips down on to my lap, which can be quite embarrasing if Im only nipping around to the shop :(
    does anyone know if there is supposed to be a rubber seal between the windscreen and roof or is there any adjustment to close the gap, or does anyone know of a quick fix?? any help would be great
    thanks
  2. Rev-head
    Rev-head Active Member
    2,987
    just been looking over the ETKA catalog of the roof it shows a plug above the drives side is this letting in water?...there is a gasket that goes round but you would notice this if it was away from the seam
    Do you have ETKA
  3. Rev-head
    2,987
    convertible top lock
    gasket
    - 155871431
    gasket
    1 8G0871025
    top frame
    for vehicles with mechanical top operation
    (1) 8G0871025C
    top frame
    for vehicles with hydraulic top operation
    2 8G0871107G
    spacer plate / 0,5MM
    / front
    3 8G0871107H
    / rear
    4 ---------
    no longer available
    F >> 8G-R-009 000*
    5 N 01100830
    hexagonal nut / M8
    F >> 8G-R-009 000*
    5 N 90908301
    shouldered hex. nut, self-locking / M8
    F 8G-R-009 001>>*
    6 N 01024022
    bolt, hexagon head self-locking / M8X20MK
    F >> 8G-R-009 000*
    6 N 0197002
    hexagon head bolt c/w shoulder / M8X30
    F 8G-R-009 001>>*
    7 8G0845353F
    gasket / front
    8 8G0871497C
    retaining strip / front
    9 N 0139575
    oval head panel screw / B3,5X9,5
    10 8G0845423B
    reinforcement rail / left front
    (10) 8G0845424B
    reinforcement rail / right front
    11 8G0845429F
    gasket / left, center
    (11) 8G0845430F
    gasket / right, center
    12 8G0845427
    reinforcement rail / left, center
    (12) 8G0845428
    reinforcement rail / right, center
    13 N 01412913
    fill. hd. bolt, self locking / M5X10
    - N 90640201
    fillister hd. bolt / M5X12-E
    14 8G0845433B
    gasket / left rear
    (14) 8G0845434B
    gasket / right rear
    15 8G0845431
    reinforcement rail / left rear
    (15) 8G0845432
    reinforcement rail / right rear
    16 N 01412913
    17 8G0871387
    handle
    18 N 0133051
    spring sleeve / 4X22
    19 8G0871401D
    19A 8G0871107J
    spacer plate / 1,0MM
    20 N 01470210
    allen key head bolt / M6X15
    21 8G0871415
    collar
    22 N 0110524
    nut, square / M6
    (23) 8G0871443E
    end plate / left / PR-3FM
    F >> 8G-R-001 006
    (23) 8G0871443F
    end plate / left / PR-3FN/3FM
    F 8G-R-001 007>>
    (23) 8G0871444C
    end plate / right
    25 8G0871445
    roller
    F >> 8G-P-001 760*
    26 8G0871556A
    gas-filled strut
    28 8G0871631B
    gasket / rear
    / 1980MM
    29 8G0871593
    retaining strip / rear
    30 N 0139575
    31 8G0871633C
    gasket / left
    for roof frame / front, inner
    (31) 8G0871634C
    gasket / right
    32 8G0871645C
    for roof frame
    (32) 8G0871646C
    for roof frame
    33 8G0871829
    adjustment plate / 1,0MM
    34 8G0907317B
    micro switch
    35 N 0102631
    hexagonal head bolt / M4X6
    36 N 0115227
    washer / A4,3X9X0,8
    37 8G0898241A
    1 set of straps with mounting parts
    38 8G0871529
    foam packing (self-adhesive) / 200X1100X1
    / front
    (39) 8G0845421A
    1 set of reinforcement for roof frame
    40 8G0871597A
    adjustment wedge / 360X17X1-4
    41 8G0871325A
    limit stop
    for roof frame
    42 8G0898956
    repair kit / left a. right
    top frame
    43 8G0871289
    attachment bolt
    F >> 8G-N-002 000* / left a. right
  4. Rev-head
    2,987
    You can see there is a repair kit the numbers in the blue are the part No
