Rolling Road Question?
MingBluS3 Dec 28, 2004
  1. MingBluS3
    MingBluS3 Member
    360
    What gear do should the S3 be in when run on the rolling road?
  2. Bazza
    Bazza Member
    194
    Usually 4th
  3. MingBluS3
    MingBluS3 Member
    360
    Hi Barry,
    This is really strange, you were at the AMD rolling road day right? well all the other s3 i could tell were run in 4th gear like you say. But for some reason they ran my car in 5th gear. I do not know the reason why but i'm keen to find out. Also you may remember that my S3 had the lowest output in comparison to all the others.
    What do you think?
  4. pwnorman
    pwnorman Member
    410
    Im sure amd did mine in 5th when i got my remap will have to check but 99% certain.
  5. Ess_Three
    Ess_Three Active Member
    5,383
    14
    The car ashould be run in the gear that gives closest to 1:1 ratio of wheel speed to engine speed - which is normally 4th.
  6. NWMark
    NWMark Member
    211
    14
    I have a S3 road test here from Autocar and they list the gear ratios of the S3 box like this.
    1st - 3.42
    2nd - 2.11
    3rd - 1.43
    4th - 1.09 (final drive of 4.2 for 1st to 4th)
    5th - 1.10
    6th - 0.91 (final drive of 3.32 for 5th and 6th)
    Anyone know why the 5th and 6th has a different final drive than 1st to 4th, all the other road tests ive looked at all gears have the same final drive. e.g. Impreza WRX 3.9, Clio 172 4.19, civic type r 4.76 etc etc
    Mark
  7. MingBluS3
    MingBluS3 Member
    360
    cheers guy for the excellent answers. I just wanted to double check
  8. manxman
    manxman New Member
    14
    [ QUOTE ]
    1st - 3.42
    2nd - 2.11
    3rd - 1.43
    5th - 1.10
    Mark
    [/ QUOTE ]
    Mark, I got this from audiworld: At least it shows the ratios you posted are possible. I'm not a mechanic so I dont know if higher final drive gives economy or performance. /ubbthreads/images/graemlins/confused.gif I'd guess economy.
    HTH
    Chris.
    <snip>
    The 6-speed gearbox fitted as standard to the Audi S3 allows the driver to make optimum use of its turbocharged engine's power. Gear lever travel is short and precise: a positive invitation to make fast gear changes. The gearbox uses the three-shaft design familiar from the Audi TT quattro. The third shaft is used for 5th and 6th gear and reverse and has a higher final drive ratio. The gearbox is compact, has an ultra-light magnesium casing and can transmit high torques at low engine speeds. The gears are selected by cable to prevent troublesome vibration from being transmitted to the gear lever or the car's interior.
    </snip>
