Rolling Road Day Result!
Oranoco Sep 24, 2011
  1. Oranoco
    Oranoco Well-Known Member
    3,861
    381
    Took my old barge up to Evolve in Luton for a club rolling road day. Pretty happy with the result considering the 148,000 miles now on her and a fueling issue giving me a very rich spot (off the scale for 750rpm). 188bhp and what seems to be 220lb.ft of torque reading the graph.
    Happy days :)
  2. tangerinedream
    tangerinedream Member
    249
    klkl mate i really need to get mine done what mods you done ??
  3. Oranoco
    3,861
    381
    Not too much really, Superchip, de-cat, Milltek full system, intercooler, N75 mod and a K&N cone filter
  4. 30vquattro
    30vquattro New Member
    29
    Oranoco, what model do you drive??
  5. Oranoco
    3,861
    381
    She's just an old '96 1.8 T Sport
  6. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,143
    1,971
    Its all about the torque....good numbers
  7. 30vquattro
    29
    Ahh well you cant complain at that pal, real good figures!
  8. Jason.s
    Jason.s Active Member
    2,879
    348
    Good figures. Hopefully i wont be far off that once im finally mapped now i`ve found someone else close to me to sort it :)
    I take it the N75 mod was the screw adjustment? Did you actually notice difference when you did it?
  9. B5QUAT
    B5QUAT Member
    317
    13
    Great figures. I presume yours would be a 150-bhp as standard model?
    Can anyone explain the strange shape of the torque curve? It seems to dive bomb from about 3500rpm (bit early in the range for a decline in torque I'dve thought) then it plateaus out (strangely) then dive bombs again from about 5250rpm. Is this normal for a 1.8T? I would expect the torque to drop off more progressively than that? Is it purely due to the piddly K03?
  10. aragorn
    18,134
    764
    i think thats the rich spot he refers to?
  11. B5QUAT
    B5QUAT Member
    317
    13
    Ah, yeah, of course! What could be causing that? Dodgy MAF?
  12. aragorn
    18,134
    764
    could be, or maybe a boost leak, or a bad map.
  13. B5QUAT
    B5QUAT Member
    317
    13
    What boost is the car running Oranoco? Just out of interest, presuming you have a boost gauge of course!
  14. Oranoco
    3,861
    381
    The map is a Superchips and I shall have to look at the old graphs to see what they show for the fueling. I think it may be to do with the de-cat and intercooler additions. It has been suggested that the lamda may be starting to fail.
    Boost peaks at about 13psi and drops back to 10-11psi which is held through to the limiter.
    If things go well and I get the Quattro (still trying to sort a happy deal) I was planning to swipe the ECU and harness as I can then run a bit more boost (Quattro runs 12psi standard)
  15. B5QUAT
    B5QUAT Member
    317
    13
    I'm toying with the idea of getting my TQS chipped just for a bit of extra poke (torque mainly) while I get all the bits together for my GT28 conversion.
    If I do, I'm hoping to get it dynoed after, so will be interesting to see what it produces.
  16. jamie226bhp
    jamie226bhp Member
    468
    You will only get to about 190 or 195 bhp max on dn ajl as they are already pushing the tiny turbo on the 12 psi, so probably best saving the £300 unless u can get it done cheap
  17. B5QUAT
    B5QUAT Member
    317
    13
    So I believe, but it's the extra 40-50lbsft that I'm more interested in. Know what you mean though, that money would buy my front mount!
  18. Geeman
    Geeman Low Life
    1,318
    N75 mod...? Do tell.
  19. Bradderz_1988
    3,946
    235
    On the top of the n75 there's a little flat screw head in a hole turn it half a turn anticlockwise and it will kick the boost in a bit harsher !!!
  20. Geeman
    Geeman Low Life
    1,318
    Huh. Cool. Cheers.
  21. Geeman
    Geeman Low Life
    1,318
    Can't find the screw. Is it down that little hole?
    [edit] It must be. I think it's rusted up as it won't move.
  22. jamie226bhp
    jamie226bhp Member
    468
    What's the standard torque on these then as would be interesting to see what I've gained
  23. Oranoco
    3,861
    381
    Found my original dyno plot from chipping the car as a factory standard vehicle and it made 148bhp with 156lb.ft of torque
