Rod bearings
IrishDave Apr 28, 2013
  1. IrishDave
    IrishDave Active Member
    682
    45
    What do you suggest? Oversized rod bearings or standard.
  2. <tuffty/>
    21,869
    4,198
    Why would you use over size? only need that if the crank has been reground... stick to std size bearings if doing a straight swap..
  3. badger5
    9,598
    2,060
    if you mean additional clearance ones, eg +0.001" then I would only use these on big power 450-500bhp+ applications.. where you might want to run a smidge more clearance.. Badgerwage runs +0.001" for example, but I dont use them on normal bt builds.. sub these power levels.
    as opposed oversize which is as tufftys says a regrind type thing re crank etc.
  4. IrishDave
    682
    45
    Should have been clearer. Additional clearance is what I meant. Thanks for the info.
  5. Broken Byzan
    13,237
    466
    Additonal only on high power free revving race engines IMHO
