rocker cover and cam chain adjuster gasket part no....
superkarl Jun 9, 2011
  1. superkarl
    superkarl MAN OF STEEL
    9,595
    2,474
    Does anybody have the part numbers for these two gaskets? Id like to order them on my lunch, ive done a quick search but its really difficult on my phone.
  2. Westy
    Westy Well-Known Member
    17,443
    1,105
    Not sure of numbers mate but just speak to the Audi parts department.
  3. Westy
    17,443
    1,105
    You need 14 and 18 below mate, I'm looking for the numbers for you:
  4. S3Lol
    S3Lol Member
    422
    I think I will have to replace the half moon shaped gasket as well soon. is there anything worthwhile that would need doing while the rocker cover is off?
  5. Westy
    17,443
    1,105
    YEah clean and paint/powdercoat the thing. Look in my progress thread, I painted mine matt black.
    S3Lol likes this.
  6. superkarl
    9,595
    2,474
    Cheers westle! Is that the diagram that will come up on there screen, maybe I can just quote the numbers 14 and 18
  7. Westy
    17,443
    1,105
    Yeah that's off ETKA so that's what they will see.
  8. superkarl
    9,595
    2,474
    Just got off the phone with parts, £30.71, Jesus Christ lol, that sound about right for the 2?
  9. pj123
    pj123 Member
    307
    13
    18 is 058 198 025 A. Not sure about 14. In ETKA, sealant (AMV 174 004 01) is listed for AUM, ARX, AGU, AUQ, ARY, AQA.
    I have an APY engine so no idea why sealant is not recommended and so I've no idea if i should be using sealant or not at the moment.
    You will also need VW tool 3366 which is £10 from audi to compress the chain tensioner
    Any advice on screwing down the tensioner with this tool and replacing the gasket and half moon. By 'any advice' I mean what are the ways you can cock up this job?
  10. Westy
    17,443
    1,105
    Yeah sounds like Audi prices ;)
    I used some blue silicone sealant from my local motor factors. It's in a yellow tube but called "blue" I think!
    Oh and you dont need the tool. I undid the 2 screws on top of the tensioner then lifted it up with 1 hand while using a tiny flat head screwdriver to manouver out the old gasket. Get a mate to help, it's much easier.
  11. pj123
    pj123 Member
    307
    13
  12. pj123
    pj123 Member
    307
    13
    Thanks Westle, I bought some Hymolar Blue and have sump sealant as that is the next job. An audi mechanic reckoned on using just a bit of the sump sealant on the sharp angle changes around the cylinder cover. Not sure if i should just use the blue stuff all the way round on both sides of the gasket or not. Guess i can remove and add blue stuff if it leaks. The new rubber gasket has ribs along the seal so it looks like it shouldn't need any sealant.
    My only concern with the tensioner gasket is loosening the chain so much that it could jump a tooth lower down the engine where i cant see. I guess if line up all the timing marks before i start then there is a check in place.
  13. Westy
    17,443
    1,105
    I only applied sealant to the under side of the outer gasket and on the 2 blue marks on the cam tensioner gasket.
    You dont need to loosen the chain at all mate. ElsaWin says to remove the cams and all sorts of stuff but Dean at 4Rings recommended just un doing to 2 hex bolts on top of the tensioner then it can be compressed/lifted the few mm it needs to get the old gasket out and the new one in. I've done 3 cars like this now with no problems.
  14. superkarl
    9,595
    2,474
    Thanks for all the input and advise guys!
  15. Sam_
    Sam_ Down under
    3,038
    480
    I recognise that screenshot Westle ;)
    I got quotes for these and were sky high (parts are here!) but here's the numbers:
    14 (chain tensioner/camshaft adjuster gasket set) is B 058 198 217
    18 (cam cover gasket) is B 058 198 025 A
    Here's an updated screenshot for future reference:
  16. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Very useful thread this :)
    Ordered the parts from the part numbers posted above, prices have gone up a little as for both gasket kits total was about £40.
    Followed the guide from the link posted but used the Westy method of changing the cam tensioner gasket. I found out there was actually 3 bolts on the tensioner itslef that needed removing and then 1 more that was inside to allow the tensioner to be easily lifted up to remove the old gaskets and half moon.
    All back together and hopefully no more oil leak for me. I would say it took about 2-3 hours to do the job and this included cleaning up the inside of the rocker cover too.
