Road Noise Tyre Choice
manor13 Apr 12, 2014
  1. manor13
    manor13 Active Member
    726
    110
    43
    My 8P sportback has a lot of road noise which is annoying my prev ED30 wasn't as bad and it ran on Michelins from memory. the 8P is running P-Zero's all round at the moment it's my first experience of these tyres are they known for road noise? anyone had this and found a better option or is it a trait of the audi's .
  2. Artimus
    Artimus Shortback
    2,017
    485
    I've found that once tyres start to get below around 4mm the can get noisy. Using Eagle F1 Assy2 at the mo and they're fairly quiet on good surfaces.
  3. 964kevin
    964kevin Member
    109
    Bridgestone are noisier, My Pilot sport 3's are quieter, but still noisey depending on the road surface obviously...PS3 and F1 I think are similar in road tests
    k
  4. mjr901
    mjr901 Guest
    Dunlops from memory are the quietest. They sit high in the price range with some of the big boys, so usually would get picked second, so people's experience is low.
    Michelin PS3, Eagle F1's and Conti 5's are the common choice and all as good as each other.
  5. max69vk
    max69vk Active Member
    862
    57
    Go to somewhere like blackcircles.com & they'll give you the dB rating of each tyre (lower being better) I personally use Goodyear efficiency grip & compared to the Michelins I was running they are silent. As mentioned before, once they get past about 4mm they all tend to get a lot noisier anyway.
  6. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    On the slightly mid range end I just bought some falcons bloody good tyres I can't fault them easily stand up against some of the bigger brands although I admit the ps3 and f1 are an amazing tyre but at 90 quid a corner the falcons are great really grippy in all weather and the noise is very low.
  7. spencer361
    spencer361 Member
    261
    I have toyo proxy tr1s on the back down to 4mm and it sound like both of my rear wheel bearings have gone!
  8. c_w
    c_w Well-Known Member
    1,169
    91
    The A3 is noisy by default for tyre noise. I've got Goodyear Assymetric 2 on and they are ok, but road noise is still marked. I don't know why Golf Mk5s seem to be inherently quieter as they are essentially the same car.
  9. Sayam
    Sayam Well-Known Member VCDS Map User
    2,718
    640
    Since I got my 4 wheel alignment done from wheels in motion my car is less noisey
  10. PRCPTN
    PRCPTN New Member
    13
    I have Yokohama Avid Envigor's on and the 2 on the back have cupped due to bad alignment....you have no idea what "noisy" is! LOL! Gonna replace them once I get coilovers on in a couple weeks.
  11. TwoFlatTyres
    TwoFlatTyres Member
    43
    I recently swapped from Dunlop sport max to Pirelli p zeros and the pirellis are by far so much louder.
    I wouldn't get p zeros again, that's for sure.
  12. S3Alex
    10,851
    4,838
    I've used quite a few different tyres now,and the Michelin Supersports are probably the best all rounders I've tried.
    Lots of grip,good in wet or dry conditions and very little road noise.
    I also had Toyo R1Rs,which were pretty noisy,but nothing like as noisy as the R888s on the car now.....they buzz at certain speeds.
    spencer361 likes this.
