RNSE screen lacquer worn off
immo Sep 29, 2013
  1. immo
    immo Stop me
    275
    40
    The best way to describe this is to post a picture.
    It looks like a previous owner has used some sort of abrasive cleaning product on the screen and it has worn away a coating. It looks really messy around the edge though so I want to know what I should use to try and get the rest off? I have no idea!
  2. NHN
    29,596
    1,782
    PlastRX
  3. pablo
    pablo Active Member
    985
    60
    any abrasive compound should do it. I used some G3 to do mine about an hour ago lol. Then ordered a new stick on antiglare cover. £4.10 and used by other members on here.
    it looked bloomin awful before I took the coating off so well worth the agro.
  4. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Second this...
  5. immo
    immo Stop me
    275
    40
    Righto I'll give it a go
  6. immo
    immo Stop me
    275
    40
    Hmm so I bought some Plast RX but it specifically states on the back "not for use on coated surfaces or LCD or navigational system displays"! So I'm a bit wary about using it. Is this just because it will take the coating off? (i.e. the coating which has already come off) or is it going to melt my screen or something!
    Would feel more comfortable if someone else has actually used this on their rnse :S
  7. NHN
    29,596
    1,782
    I wouldn't of advised, unless I knew it would do what you need it too.
  8. Adam.
    Adam. Meow.
    662
    34
    Looks to me like it's just grubby and needs a good clean :S
  9. NHN
    29,596
    1,782
    Unfortunately not.
  10. Adam.
    Adam. Meow.
    662
    34
    Quite worrying tbh.
    A new screen isn't the end of the world I suppose.
  11. pablo
    pablo Active Member
    985
    60
    why do you need a new screen?
  12. NHN
    29,596
    1,782
    Stop scaremongering, he's been advised correctly by several people who know about the product, IMMO it will work perfectly fine, takes a while to gently rub it of evenly, but is fine to use, based on someone with actual experience of doing this specific job multiple times.
  13. pablo
    pablo Active Member
    985
    60
    they advise you not to use because it will rub the coating off a good unit. which is bad. but you WANT to rub the coating off, as its bad. so its doing exactly what you want it to.
    Honestly I done mine as its like a new unit. Havent put the antiglare sticker on yet as havent had any issues with glare.
  14. immo
    immo Stop me
    275
    40
    I did do this yesterday and it worked just fine. What pablo said is right about the warning on the back, it's just because it takes the coating off but that's what I wanted to do anyway of course. Looks a lot better now but I can imagine glare might be an issue, where did you get your sticker from?
    Thanks all
  15. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    606
    34
    For future reference can we have an after photo for the next person that uses the search feature for the same solution.
  16. Adam.
    Adam. Meow.
    662
    34
  17. NHN
    29,596
    1,782
  18. pablo
    pablo Active Member
    985
    60
    **** pic sorry
  19. immo
    immo Stop me
    275
    40
    I'll get a pic tomorrow (mine looks a bit better than yours pablo, no offence!!)
  20. NHN
    29,596
    1,782
    You need to remove the screen & then the plastic surround, so you can do it properly or you end up with corners with the covering still showing.
  21. turbonutz
    turbonutz Active Member
    421
    61
    may be stupid but what if cotton bud was used, could that prevent dismantle and still get happy results?
  22. NHN
    29,596
    1,782
    No, its not really suitable as would end up with excess liquid inside screen.
    turbonutz likes this.
  23. MacrosTheBlack
    MacrosTheBlack Member
    212
    20
    Got a dodgy bit of scuffed antiglare coating on mine so just ordered some PlastRX. Will give this a go and post up a before and after pic.
  24. pablo
    pablo Active Member
    985
    60
    I didnt bother with the edges as its not noticeable on or off really. The difference it made to the main area of the screen though is night and day.
  25. MacrosTheBlack
    212
    20
    As promised here's some pics of my RNSE screen antiglare layer removal. Looks tons better now and very happy with the result. Took a couple of hours to remove the unit, disconnect the screen, remove the gloss surround bezel and carefully polish off the antiglare layer with the recommended Meguiars PlastRX. Thanks to posters above for the tips.
    Before, process pics and afters:
    NHN and Muzza80 like this.
