Rnse retrofit & DAB to Black ed A3
mojo555 Jan 17, 2011
  1. mojo555
    mojo555 Member
    331
    21
    Posted the following in the sat nav forum but no responce....
    anyone help
    Is it poss to add the sat nav unit and dab to a 2011 black ed sportback, and if so any idea of cost?????
    Thanks....
  2. Dean's A3
    Dean's A3 TDI S3 Hybrid
    252
    What unit have you got at the moment?
  3. sub39h
    sub39h Active Member
    2,502
    i don't think you can get DAB for the 8P no matter what you do to it.
    for the latest version of RNS-E there's a user on here called NHN who sells the MY10+ RNS-E units, but they're not cheap. PM him for prices.
    then you'll need all the wiring and DVD, antenna etc, plus paying someone to code it for you if you don't have VCDS (which NHN also sells)
  4. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    RNS-E from eBay you're talking ~£400, plug&plug for you.
    You may experience radio problems with the RNS-E though due to a different radio setup, this can be amended at a cost of ~£150 for the correct items to be ordered.
  5. mojo555
    mojo555 Member
    331
    21
    Thanks will pm NHN, it is for my brothers car which is due to arrive for march delivery, it will be the standard unit with bose....
    sure i read somewhere you could somehow add dab????
  6. PilotAudi
    PilotAudi New Member
    2,352
    479
    I don't understand why Dab could not be added, it is a great system which I have on other car.
  7. Dean's A3
    252
    You CAN get DAB on the 8P, but you need the OEM Hybrid TV tuner to do so!
  8. sub39h
    2,502
    i think it's purely down to the age of the 8P. remember the original 8P didn't come with a/c or even a CD player as standard
    ah yes, i'd forgotten about that solution. i wanted DAB in mine, but i thought getting a digital TV tuner was too much extra cost for DAB.
  9. 1animal1
    9,978
    whats the extra cost roughly?
  10. sub39h
    2,502
    i don't remember... i don't think the cost itself is the problem, it's just that when you're spending £1k+ on the head unit, £300 for bluetooth, £200 for AMI and iPod, then you need all the wiring and antenna and disc - and to get it coded if you don't have VCDS
    then to add a TV tuner and video-in-motion? it was all a bit much lol
  11. 1animal1
    9,978
    yeah see what ya sayin.... if the car i get doesn't have it already, my plan was to go RNS-E.....then add on the Parrot MKi9200 which is an absolute gem both for bluetooth and ipod functionality - no way am i going back to the Denison era with a blind shortened playlist function - i'll hide the tft screen if i cant find a spot that looks decent.
  12. sub39h
    2,502
    apparently the new Dension Gateway Five is a much advanced unit, but it doesn't like pairing with iPhones and it only shows track names on DIS, not on the HU... and you can't actually call out using the steering wheel with iPhones for some inexplicable reason. apparently they were working on a fix, but when i emailed them they seemed to be dodging the question. i said to them clearly that that was a sign to me that kit couldn't possibly be working as expected if they weren't answering simple questions about it, so i decided against it and i'll just go OEM. if the limitations are ok for you then i'd defos recommend the Dension because it's a lot LOT cheaper than OEM (tho probably not parrot)
  13. 1animal1
    9,978
    Good job i don't have an iphone then ;) Samsung Galaxy for my afraid :)
    I had the Denison on my 8L, got it for approx £120 before they upped it to circa £160 a few months later? i sold my unit as the controls on the HU just do not have enough range and the screen couldn't accommodate the required info even if they had upgraded it. I then sold my CK3200 parrot and paid just under £200 for the MKi9200 including the Connect2 aux adaptor needed to get the rears speakers working..... its been 'bob on' ever since
    I'm all for keeping things as OEM as possible, but unless i can get the same functions and accessability to my ipod that my parrot can and through the RNS-E......then i aint changing.
    Does this Denison look remotely better apart from the iphone issue?
  14. 1animal1
    9,978
  15. sub39h
    2,502
    well it would be hidden. it's basically just a black box that everything wires into then you bring an iPhone wire out for it. i was gonna hook it up to one of these:
    spec.dock - complete iPod and iPhone vehicle integration
    and put the box itself under a seat (where the OEM BT would go) or behind the HU or something
  16. beanoir
    beanoir Large Member
    2,171
    31
    2 potential solutions that I had been looking into were either the RNS-e and DAB from an A6, or the RNSe from a new VW Golf which is touch screen and has DAB. Never got around to looking into the techie issues, but i'm sure you could get both to work if you were that way inclined
  17. 1animal1
    9,978
    my head hurts (revisions out of the window today :) )
    That looks really good!! a bit like that job someone did on here a couple of years back with the Resin in the ash tray?
    My Ipod is going to be Glovebox mounted as cant be arsed to remove it everytime i leave the car..... i'm now thinking along the lines on the BT module instead if its any good, it does look better having it integrated....leaving me with the ipod problem.
    Phatbox is an option.... i would like some sort of visual aid though to see my playlists and the songs within
  18. sub39h
    2,502
    your RNS-E has SD card slots. 2x 32GB if you go for the latest version... so you could just leave the iPod
  19. sub39h
    2,502
    my understanding is RNS-510 from the Golf is just no-no
  20. 1animal1
    9,978
    interesting thought, and i suppose it would modernise the car somewhat.....
    I would imagine theres a few things to sort, firstly the VW emblem on start up.... probably too techy for me, i'll wait till NHN gets his **** in gear :)
  21. 1animal1
    9,978
    ahh, so i guess they are the library and you create ya playlists on the HU?
  22. sub39h
    2,502
    dunno man, only ever briefly used RNS-E in a Lambo
  23. beanoir
    2,171
    31
    Yeah, i've no idea if either option is possible, and not i'm not techie enough in this department to know either. I opted for the TomTom cradle in the end and use internet radio on the iphone, which is as good as DAB in most cases and a much wider choice of stations, just doesn't look as posh as an integrated HU.
    I do however like the look of that Spec Dock, thats a pretty nifty looking idea!!
  24. 1animal1
    9,978
    looks like it's an ongoing problem - i'm not up enough on it all, Vagcom error codes and logging are as far as i go.....
    I think the RNS-E with BT...the SD slots must allow you to play around otherwise why are they there, you'd assume (many a cock up created from assumptions!!)
    The TV is something i'll make a call on once the basics are sorted, it'd be nice to have DAB and TV but the useablility will probably be wasted on my weekly 10 mile commute
