RNSE retrofit- can't move bose pin as its already in use with another wire?
gizm0 Apr 28, 2012
  1. gizm0
    gizm0 Member
    187
    hi all im upgrading from a concert cd player in my 2008 57 plate A3, came to move the bose wire from pin 6 to 7 but there is already a purple/grey wire in pin number 7, on my old stereo it says the bose pin is slot 3 but there isn't a cable in there but my new head unit (LED version) says its slot 7 so i can't move it, any help appreciated asapplease guys.
    thanks
    Dan
  2. Lewbo
    Lewbo Well-Known Member
    1,266
    104
    Bose is brown and is in number 5, the one in pin 7 now Is for your aux in port, you need to buy a multimedia plug from Audi about £3 and take out aux ground, aux left and aux right and put them Into there, look ok back of rnse and tells you the numbers
  3. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    If you have an aux input it usually goes where the BOSE pin now needs to be.
    Check this out on my thread I did a while back!
  4. gizm0
    gizm0 Member
    187
    ah big help guys! thank you i will remove al aux pins now and get a multimedia plug ordered monday morning :) do you by any chance have a part number for the plug? will my aux work ok then?
  5. gizm0
    gizm0 Member
    187
    got it, if anyone else needs the code for the 32 pin block is 1J0 972 977 G
    just got to hope the wires will reach to it now lol
  6. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    They wont, you'll need to cut at the loom and remove the 3 Aux wires then re-tape it.
  7. gizm0
    gizm0 Member
    187
    i have another plan ;) without cutting the loom :)
  8. crunchie
    crunchie Active Member
    880
    77
    Handy thread, thanks!
  9. Dubport
    Dubport Member
    32
    Sorry to sound like a numpty but I fitted this unit (RNSE) to my 2010 black edition sportback two weeks ago, my car has Bose but seems tO be working fine, do i need to buy the extra plug and shift the above wires around? Any advise would be great.
  10. jb0o
    2,664
    118
    You only need to move the aux wires to the 32pin AV plug and Im assuming you dont have an AUX otherwise it wouldnt be working so you only need to move the Bose pin from 5 > 7 (or vice versa, cant remember of top of my head) - pin locations are shown on the pin diagram on the Radio units.
  11. jb0o
    2,664
    118
    Whats your plan?
    I may have confused when I said cut at the loom, I just meant cut at the loom tape and remove the 3 wires then re-tape.
  12. gizm0
    gizm0 Member
    187
    Yeah I see what your saying but to keep it all neat maplins sell little extension wires for computers which fit the connections pon the cables and back of the headunit do no cutting required at all so keeps it all neat without damaging anything :)
  13. Dubport
    Dubport Member
    32
    Yes mate I do have the aux socket but I haven't checked if it's working or not? So I just need to mo ve pin5 to pin 7 is that correct?
    just wondering what difference that will make as I said it seems to be working fine as it is?
  14. jb0o
    2,664
    118
    Sounds good but that makes it more messy in my opinion.
    I cut the loom tape to reveal all the wires, removed the 3 aux cables so they can reach the AV plug and retaped using proper fabric loom tape so looks all OEM. No cutting of wires, just the tape itself ;)
  15. jb0o
    2,664
    118
    If you went from Concert II+ (which you must have otherwise you wouldnt have an AUX) to RNS-E then yes, your AUX wont work.
    You'll need to order the 32pin AV plug listen above to reroute the 3 AUX wires into here then move the BOSE pin from pin 5 to pin 7.
    Without moving the pin everythin will appear to be working but the BOSE system wont be getting used so will just sound like the normal system.
  16. gizm0
    gizm0 Member
    187
    Each to their own then ay! As long as it works lol
  17. Dubport
    Dubport Member
    32
    Ok guys I ordered the plug today, sorry to over it again but could some of you please just summarise what I have to do with the wires?
    i know that pin 5 goes to pin 7 but what else, and do I need anything special to remove the pins from the plugs?
  18. gizm0
    gizm0 Member
    187
    got my plug today and will be wiring it up shortly, you need to move the 3 aux wires from the existing plug to the new one, look on the back of your old stereo it will tell you what wires they are then you need to look on the back of your new one to see what locations they need to go into
    hope this helps
