RNSe retorfit in 2007 A3/S3 ZF short to earth
JohnS3 Nov 26, 2007
  1. JohnS3
    JohnS3 Active Member
    3,032
    Probably only relevant to anyone who has done this.
    Those clever chaps over at audi4ever.at have worked out a fix for the ZF short to earth issue that doesn't require re-wiring the antenna system in the tailgate. Link
    The two HF feeds from the antenna system connect to a golf/passat diversity converter and then onto the RNSe as a HF/ZF connection. The chap has posted a schematic for the connector cables too if you want to have them made up by an Austrian company called Krenn.
    I've costed some of the parts from a VW dealer -
    Golf/Passat diversity adaptor 1T0035530 - £108.61
    Power connector for the above 1C0 973 119 - £1.49
    This is a picture of the diversity adaptor mounted on its carried plate
    I've asked vagparts for a price on the adaptor, if's it's significantly cheaper than VW I'll buy one and see how I get on with it. I'll post back any results if I actually get around to it.
    If anyone can translate the page better than bablefish feel free to to do so.
    From what I can make out, the ZF issue is fixed and the reception is much better too.
  2. JamS3
    JamS3 Active Member
    2,258
    20
    John
    What is the ZF issue as iv'e not really noticed anything wrong on mine apart from the obvious vagcom error on the radio part?
  3. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    I have this same error on my rns-e (fitted two weeks ago).
    I presume this is what causes the radio reception to be very poor for stations that worked fine on the symphony II+
  4. IH786
    IH786 Member
    145
    Thanks for posting this JohnS3 :icon_thumright: Was hoping there would be a fix for this, as i'm looking to retro-fit the RNS-E sometime next year :)
  5. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  6. JohnS3
    3,032
    Marc hit the nail on the head, it causes poor reception.
  7. JohnS3
    3,032
    Good news Lee, do you know someone who can make up the required cables locally? If so I could do with a set too.
  8. MarcQuinlivan
    2,539
    JohnS3 has posted this on navplus - seems to explain the cause of the problem.
    Thought I'd post it here, rather than having to trawl through the german site to get the gist of it.
  9. JohnS3
    3,032
    Oh yeah, so I did!
  10. JohnS3
    3,032
    Part costs from vagparts -
    1T0035530 £77.81+vat
    1C0973119B £1.19+vat
  11. MarcQuinlivan
    2,539
    would it be cheaper to just buy the sharkfin fm\am & GPS antenna?
  12. JohnS3
    3,032
    Good plan, but you'd then have a ZF open circuit error showing on vagcom and the dealer VAS system. I did read that the sharkfin FM reception wasn't too good, I'll have a search for the link. Has anyone done this?
  13. MarcQuinlivan
    2,539
    surely not, because the sharkfin is designed to work with the RNS-E, so would have the necessary ZF circuit on it.
  14. JohnS3
    3,032
    As far as I'm aware the fin isn't powered and would only provide the GPS signal to the RNSe. Still looking for that link.....
    EDIT and of course an FM signal. Doh!!:keule:
  15. sakkie69
    sakkie69 2008 Audi S3
    199
    Is there a link on what to rewire in the rear to make the error go away?
