RNSE removal
loudchris53 Mar 18, 2013
  1. loudchris53
    loudchris53 Member
    402
    Hi all, i may be part exing my car this weekend so want to try and get the rns-e out and put my old symphony one back in, aside from getting radio keys and pulling the unit out do i just take the plugs out the back and but them into the symphony?
    Chris
  2. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    74
    Id say that your one the right lines with just removing it, maybe replace an adapter if the RNSE was installed.
    Not 100% sure though
    Ps I'd be intreasted in this if the price is right. Cheers
  3. fangio
    fangio Well-Known Member
    1,514
    180
    If the quadlock in the back of the rns-e won't fit the Symphony, disconnect the 3 plugs and plug them all into the Symphony. You can't mix them up!
  4. BlueSpark
    BlueSpark 6th Gear
    386
    If you originally had the symphony and retrofitted the RNS-E, then just remove the RNS-E unit and cable adaptors for the quad lock. Plug in Symphony with original leads and recode to let the car know you no longer have sat nav installed.
  5. Brodster
    Brodster Well-Known Member Team Ibis Audi S4 Audi Avant Owner Group
    3,548
    886
    And if its got Bose swap the pins over.....theres a sticky about it that I made up about converting to RNSE.....just do the reversal.
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    Bose pins only effect post 2007 cars, and the car will need to be recoded back for the Symphony stereo....
