RNSE Problems.
a3rider Dec 19, 2011
  1. a3rider
    a3rider Member
    64
    Hey guys, im having problems with my RNSe, it keeps saying the CD is unreadable, but its the same cd that worked before, the gps anetna might be gone but that shouldnt mean that my CD isnt readable. Anyone had problems like this let me know, any advice please. Thank you in advance.
  2. kite
    kite Member VCDS Map User
    677
    run a lens cleaner in the rnse
  3. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    TDK ones are probably lesser of the evils if you can get one.
  4. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    Does it play other CD's ?
  5. a3rider
    a3rider Member
    64
    i cleaned the cd, it was a little dirty and it made it worse. ill clean the lens tmr and see if that makes a difference.
  6. a3rider
    a3rider Member
    64
    no it doesnt, i tried a dvd it wouldnt read it, it wont even eject the cd had to open it and do it manually, even tried with a vagcom. nothing
  7. a3rider
    a3rider Member
    64
  8. paddy
    5,168
    136
    It will not read DVD's anyway but should play CD's
  9. a3rider
    a3rider Member
    64
    it plays cd fine :( wtf is wrong with it. i just got the lense cleaner its cleaning lets hope that works ay, if it doesnt :(
  10. a3rider
    a3rider Member
    64
    IT DOESNT WORK :( plays cd, cleaned lens and still wont play navigation disc, recognizes it for a split second then it says unreadable.!!
  11. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Try and borrow another navigation DVD. It just may be that your current nav DVD has gone to DVD heaven.
  12. warren_S5
    7,210
    2,486
    Yup, DVD's can pack up. I made a copy of the original on a Vertabim DVD for my old an in about a year it just stopped working. Put the OEM disc in and it was fine.
    Try giving the disc a proper clean up, and if not look for a replacement off the Bay.
  13. a3rider
    a3rider Member
    64
    this is a burned version not the OEM i think, maybe if i can just re-burn it will that work?? the disc look fine no scratches or anything.
    what you think.
  14. a3rider
    a3rider Member
    64
    the ones of ebay are expensive :( could i just re-burn my cd if its not good? what you recon
  15. LWNY
    LWNY Member
    161
    a burned DVD is darker than a original DVD, thus will be harder to read. Also, alot of other factors like DVD format, brand of DVD+R, etc, all add up to as variables that, if your RNS-E can't read it, doesn't prove anything. But then if it does read the DVD, then you could be in luck. But the best way is to find someone with an original DVD and try it out.
  16. a3rider
    a3rider Member
    64
    it worked fine few months ago, ill try reburning it before i get someone else to lend me a original dvd. :( just my luck.
  17. kite
    677
    a copied DVD is harder for the laser to read, this can cause the laser to fail.
  18. a3rider
    a3rider Member
    64
    same would happen if i had burned cds, im sure it wouldnt fail after such a short life, if it did i would be very upset. still not fixed working on the problem tho.
  19. Harrelson
    Harrelson Member
    173
    mine gave me the same exact problem. tried cd cleaners etc nothing worked,
    shared story with bro (got similar car). he told me to open rnse and clean the laser with cotton wool. i rubbed the laser with an ear bud and it was black! previous owner of that rnse must have been a heavy smoker. since then its worked flawlessly, calculating routes takes 1-2sec now compared to 5-6 before.
  20. a3rider
    a3rider Member
    64
    thank you, i will definelty give that a try, even tho the car was never smoked in and it plays cds fine. but still thank you. willing to try anything. :)
  21. a3rider
    a3rider Member
    64
    Hey guys just an UPDATE :) spent all that time and effort on cleaning products cleaning it opening the rsn-e, all it needed was a new disc i guess. Because i got a newest version burned of course :) and it works fine. ALL IS GOOD I GOT NAV :) yayayaya thank you all for your advice.
